M
Mark B.
Guest
<shrug> I've never run out of battery power, so the ability to use the camera while plugged in is of no concern to me.But the moment you ARE next to an outlet, you can hook up and start using your laptop immediately, even if you happened to exhaust both batteries on said beach.USB charge or not, I don't take my laptop out to the beach or other areas where there is no source of electric. If I were that remote from an outlet, I'd be sure to have an extra laptop battery with me.With completion of the USB power delivery spec, which allows up to 100w of power, why are no other cameras other than point and shoot using USB to charge? Even some laptops now have usb charge.
My Canon XA20 camcorder has an AC port, and will charge the battery if connected. I do have a two-hour battery, and a four-hour extended battery, so I can definitely take it 'a few feet away from an outlet' . But if shooting next to a power source, I can connect and not worry about running the batteries down.If my camera is a charger, I cannot take it more than a few feet away from an outlet to use it. Pretty useless. I have multiple batteries, and a couple chargers so I can charge the batteries independent of the camera.But with cameras it seems were are forced to use proprietary connectors.
Are there no DSLR cameras on the horizon that can be charged via usb?
Mark
