Having to choose between an underwater housing and a 'proper' rugged camera, looking at the specs and positive reviews, I decided to give TG-4 a go. After all, it's quite pricey, so it must be good, right?
First impression was OK, since it is a very snappy camera and also easy to control. This is also helped by the no-nonsense menu system, very appropriate for such a model.
Had lots of fun with the Microscope mode. Wow, it really works. By the way, grab the circular light for it, unless you want to constantly be put off by the longer shutter speed you have to select in order to compensate for the lack of light at such proximity. I almost feel like that ring should be included in the box.
Alas, my biggest two complaints: IQ and ruggedness. See, checking the captured imagery on a proper screen reveals just how little detail this camera is able to solve. It's true, when light is aplenty, it does nice exposures, if a tad on the neutral-cold side, but they always fail closer scrutiny. When light goes dim, however, don't be fooled, that F2 lens and integrated flash unit never result in any decent photos. It's downright horrible for a dedicated camera, be it rugged or not. Had much better results from pocket models which used to cost 1/2 to 1/3 of TG-4's price on their launch. Yes, you can use longer tripod exposures, but detail still falls short of even many mobiles. In fact, there are lots of better mobile options, at least if you're willing to live without a zoom.
Ruggedness: two dips into seawater and the same amount of appropriate clearing / drying procedure later, the glass in front of the lens showed peeling. It was the hydrophobic coating. Same for parts of the LCD. Mind you, the Black Sea isn't exactly as salty as the Greek Aegean and it was submerged for a matter of minutes.
Instantly, flare response changed, revealing a huge weakness in handling lateral light. With a 25mm equivalent focal length, it proved difficult not to be affected by it.
So, long story short, I returned it and asked for a refund. Will get a proper underwater casing for a camera which is actually able to take competent underwater pictures.
On the plus side, it looks like a good pool companion. I'm not sure, however, why you'd pay so much for a pool/rafting camera.
Pluses:
- Extremely snappy, decent exposure in good light
- Easy one-handed control, intuitive and simple menu
- A plethora of modes, underwater color balance excellent
- Feels pretty solid
Minuses
- Horrible image/video quality in all but the best possible light
- Lots of highlight clipping
- Color rendering options limited, JPEG curve profiles not very attractive (subjectively)
- Hydro coating started to peel off after just two dips, in spite of appropriate maintenance and protection. LCD scratched easily. Tough luck, huh?
Overall:
Cannot recommend it at all. Not that tough, stunningly bad IQ in all but good light, detail smearing even at the lowest possible ISO values.
