I am not a professional photographer, but once in a while I am volunteering to help photographing an internal office event or something like that.
For such event photography, I will usually use two lenses with large aperture and I will mostly bring two bodies, my GX8, and my GX7. One of the lens will be a normal zoom which most of the time will always be my 12-35mm f2.8, And the other lens will be a tele lens. The choice for such tele lens will be Oly 45mm 1.8, this lens, Oly 45-150 2.8, or the Pan 35-100 2.8.
Oly 45-150 2.8 is too big so I'm not interested in that at all. Although I'm sure it's a fantastic lens!
The 45mm....it's just too short, so I don't use it. It's small, sharp, and really great for portrait as well as for general use, but it's not working really well in event photography.
The 35-100 2.8 from Panasonic makes so much sense as the tele lens in this situation (flexibility of zoom, IS for my Panasonic bodies, almost as sharp, not too large as well), but I somehow purchased the 75mm lens instead. I am more attracted to the f/1.8 aperture as well as the focal length more than anything to be honest ...
Anyway, I use this lens to shoot something far away from me in the event, to get some close up pictures. Mostly, it's gonna be a candid of some people listening to other people's speech, or a close up of the person delivering the speech. I am mostly after their facial expression and shoot very far away from them so they don't notice me. The 75mm is delivering quite a tight field of view, so it performs well for such task. So the 75mm is my go to tele lens for event photography.
Since this is not a zoom lens, I have to move back and forth to frame my shots properly. Luckily I have the 12-35mm with me bolted to the GX8 all the time, so I can use the long end of that 12-35mm lens to mimic anything between 35mm and 75mm by walking a bit closer to the subject, and then I use the 75mm to mimic anything a bit longer than the 75mm by walking closer to the subject or by cropping in post.
The lens is amazingly sharp even wide open, and at f/2.8 I think it's already reaching its peak performance(not much visible CA in my photos at least).
I use flash (sometimes on camera bounced to something for soft light effect, or off camera with some modifier) and this lens will reveal any small little details in the focused part of your photo.
Sometimes, the lens is so sharp that I even have to reduce the sharpness in post when photographing a person so that the person doesn't look way too sharp, which many people don't really like. This means I also have to be careful when shooting with flash because with the wrong lighting setup I could accidentally amplify that "too sharp" effect further.
Bokeh is not a problem for this lens. At this focal length, depth of field will become thin, and you can easily kill cluttered background with this lens.
Speaking of build quality, it's all metal. It's not that heavy, but it feels very sturdy and seemed to be very durable. I have the lens for more than a year, and the paint job doesn't seem to wear off easily like my Oly 45mm or my 25mm. It's as big as my 12-35mm f/2.8, and it even shares the same 58mm filter thread, which really helps when I need to attach a low-power ND back and forth between some other lenses to do some off camera flash outdoor.
As you can see, there are so many things that I like with this lens. But there are also some things that I don't like with this lens, just to be fair.
I don't like to use this lens for my portrait/headshot lens, since I don't like how compressed everything looks with this lens for headshots. The ears look big, the head just doesn't look right. So I always prefer the Oly 45mm 1.8 for my go to portrait lens and also for headshot. It doesn't compress as much, and things look more pleasant in my taste. But if you are after such compression effect, then by all means the 75mm will give you a better option. Or the 35-100 2.8. Or the 40-150 2.8.
I also don't like to use this lens for travel. It just doesn't make sense to bring this lens for travel in my opinion. The focal length isn't really easy to use for framing an image during travel, and you are better served with something like the 35-100 f/4-5.6 or a 40-150mm f/4-5.6 to get some far-away shots or detail shots during travel.
The focusing is kind of slower compared to my other lenses in my opinion. I think it's because the lens needs to move such large piece of glass back and forth, so it's kinda slow. But it's not a slow lens by any means, it's just a bit slower compared to my other lenses.
The chromatic abberation at f/1.8 could cause a problem if you're shooting some fine contrasty details of some things. You will have to stop down a few stops to eliminate the CA problem.
I don't complain the lack of weather sealing on this lens, because for my applications I don't need weather sealing. Weather sealing will probably 1) add more weight, 2) reduce some sharpness, or 3) make it become more expensive. Or all at once.
Overall I'm happy with this lens as my event photography lens. The things that I don't like don't really matter that much, and it performs really well for my applications. It's my number one choice for event photography tele lens, and for all the things that it does, it receives an easy 5 star from me.
