The A7rii (or A7ii) LCD panel, i.e., the pivoting part, is connected to the camera's body by a flex ribbon cable. If your camera's LCD panel does not work, it's mostly due to the LCD screen which is inside the panel, behind the panel's front glass. You have to open the panel (by unscrewing the two screws at the bottom of of the panel to separate the panel "frame" from its back panel). You will see that the LCD screen is connected to a small PCB board that is glued to the back panel. This PCB board is in turn connect to the body by black flex ribbon cable the you talked about. You disconnect the old LCD screen from the PCB board and connect a new one (bought from eBay) to it. But the LCD screen from eBay has to be first attached to the old "frame" (the one that frames the old LCD you want to replace). To do this, you have to detach the old LCD screen from its frame (referred by Sony parts as "front panel"). You then detach the front glass from the front panel (frame). You then glue the eBay LCD screen to the front panel at the place of the piece of glass that you remove. I used epoxy glue with a tooth pick. You should separate the LCD board from the back panel (be careful not to bend the PCB board because it's glued to the back panel). You then connect the new LCD screen to the PCB board, and glue it back (with double-side tape). The you connect the black flex cable to the PCB board through a hole on the back panel. Test for display then attach the front panel to the back panel and put back the two screws.The flex ribbon cable's connector is very delicate. If you break it then you have to order it from Sony and open the back cover of the camera to replace it. If you know a camera repair man, bring him your camera with the parts and guide him to do the work for you. Good luck. I don't receive email notification and may reply late to posts.
