So if you want/need some JPEGs quickly as well as shooting raw for later processing I'd suggest trying Daylight or Tungsten balance with a quick chimp at the first couple of shots.You've already got your "shoot raw" answer, which is best. Fireworks are basically "fire," naturally warmer than tungsten until chemicals are added. Color balancing non-chemical fire and fireworks to a neutral balance is apt to look pretty disappointing.
Here are mine from this last 4th.I'll shoot fireworks, in the night, over a lake.
Whick white balance should i use? Auto....? It's not sunny, not tungsten....
Fluorescent maybe? Or should keep auto?
I think most newer cameras have fireworks scene mode ;-) :-DI'll shoot fireworks, in the night, over a lake.
Shoot raw, then it doesn't matter and you can apply any WB setting you desire visually later on a much better display! FWIW, I only shoot raw, keep WB to auto, which only affects the LCD preview.Ehm my camera (Canon G7X) doesn't have white balance "fireworks".
Anyway, thanks everybody, usually i'm jpeg, i'll try raw and check it out.
There's a fireworks scene mode.Ehm my camera (Canon G7X) doesn't have white balance "fireworks".
