Thedesertratz
Active member
I've had this lens for about a week and taken quite a few shots with the D810 and the new D500. It is very sharp and works exceptionally well on the D500 at all shutter speeds using VR. I did do quite a few test shots using the D810 and can say that this combination does still have an issue with "VR blur" between 1/80- 1/160 sec. This was varied and did not replicate the same for each shot at the same shutter speed and that could be due to hand holding but it did work surprisingly well at 1/15 to 1/60 sec and of course anything above 1/160. It's not that the images were necessarily blurry, pixel peeping showed the slight edge blur and normal viewing most looked relatively sharp. its a little disappointing that it still seems to have an issue with D8XX bodies but certainly not a deal breaker me as I really bought it to use on the D500.
The Lens also pairs well with my older 1.4x II and focus seemed fast and precise, Overall this combination is very light and portable and just as sharp if not sharper than the older 300 f4.
If you are looking for a compact, light system to walk around or hike with this would be a great addition to your kit, just keep in mind the D8XX VR issue before you buy.
