One of the more challenging images in Merklinger's
simpler book on the object-space method, is on p. 48, which I call "Cannon overlooking Placentia, Newfoundland."
The challenge: What aperture and focus distance do you use?
I plan to discuss this example in some detail shortly, because I've simulate CoCs based on both defocus and diffraction for several different CoC management plans. The plans compare different methods, including Merlinger's object field method.
The challenge is to manage depth of field for the best image according to your taste. If the image does not please, you could imagine that the Placentia C of C is your client, and they want a large print.
Some information gleaned from the Internet and the lens equation:
- The 12-foot (bore) canon is 50 feet away.
- The foreground pine trees are perhaps 75--150 feet away.
- The buildings you can see in the town are 2160--5280 feet away.
- The distant trees may well extend to five miles away.
Jim answered the challenge in the earlier thread, but I had not yet given this data about distances of key objects in the image.
I don't want to limit your creativity, but consider assuming the following for the sake of focusing on CoC-management issues:
- Lens, a superb 90mm
- Camera, maybe the best in FF for this image, a Sony a7RII 42 MP.
- with tripod; wind not terrible
- Camera position, time of day, season, weather, all match Merklinger's situation.
- Just one image; no panorama, no tilt-shift, no focus stacking
- You can plan deconvolution, sharpening, contrast enhancement, etc., as global changes in post.
Jim's answer is strong, of course, but it has some surprises, and we can still compare the object-space method to the image-space method to see which works better according to our tastes.
I like that photo, and it turns out you can use Street View in Google Maps to go to almost the exact camera position on Castle Hill, as far as I can tell, although I suspect the cannon has been subsequently turned to the left a bit, perhaps moved, and it is now placed on a concrete pad. At first I was dubious that the cannon was as far away as you suggest, but looking at the Street View, I suspect that you are correct.
Merklinger's method has two basic rules of thumb, at least as far as I understand it, either focusing halfway between the near and far points of interest and using an aperture setting to adequately resolve the objects according to lens' front pupil diameter; or, as a special case, if infinity needs to be sharp, focus at infinity and set the aperture to resolve the front object of interest.
Were I to photograph that scene today, I'd simply focus on the church (.700 mile or 3,696 feet away according to Google Maps) and set the aperture at f/11 as is my custom in such situations. But then I'd estimate that the resolving power of the lens at the cannon would be no more than 8 mm, which might not be quite enough, assuming the image is greatly enlarged. I would roughly estimate that about 4 mm of resolution or better is needed on the cannon, but that would imply an aperture setting of f/22 or tighter, assuming the focus is in the far distance, roughly infinity. This would give noticeable diffraction, but not so much that it would look particularly bad with sharpening.
Because significant points of interest are in the near and far distance, I don't think it is quite possible to get superb sharpness throughout. For sure, I'd ignore the background forest as insignificant, and concentrate on the cannon and the town, and so we can bring the focus much closer.
Based on the simplification of modeling blur geometrically according to the thin lens approximation, and assuming a perfectly circular and uniform blur disk, and then handling diffraction after the fact, we can come up with a better focus distance: let's also assume that the lens has its maximum sharpness between f/4 and f/8, with f/11 being only slightly worse.
I estimate that approximately 296 mm of resolution is needed on the church to visually equal the 4 mm of resolution needed on the cannon, and so we need to find a focus point where the distance between it and the church is 74 times the distance from the point of focus to the cannon.
(Focus - 50 ft ) * 74 = (3696 - Focus);
Focus = 99 feet.
Since the near point of interest, the cannon, is almost exactly half the distance to the focus point, to get a 4 mm resolution at the cannon, we'd need an 8mm aperture width, which would be f/11 again. This assumes the focus distance is measured from the center of the lens, which isn't a bad approximation in this case. This aperture setting is probably close to optimal for this focus distance, even taking diffraction into account, if you want to resolve both the cannon and the town equally well.
Practically speaking, we could focus on the trees in this situation.
http://therefractedlight.blogspot.com
