Hello all, I think this is my first post on the print forum
A bit of background that you can skip: I currently have an A4 photo printer and would like to be able to make larger prints. I considered an A3 printer, but I have some A2 size prints that I really like and want to be able to make similar ones by myself. If I got an A3, I fear I will have this nagging thought in the back of my head that I should’ve got something bigger. Also the price difference is not so big especially once you take ink costs into account. So I think I will go all the way and get A2 printer. I know it is not cost effective for me as I am a light user, but I do enjoy the processing and printing part of photography.
Now I am trying to decide between the main contenders: Epson P800 and Canon ImagePROGRAF Pro-1000. I cannot find many threads that do an overall comparison between the two, just some specific areas like ink cost (about the same) and paper size (Pro-1000 has strict 24” limit on length). So I have tried to summarise the various factors that can influence my decision based on reviews I have read. What do you think, do you agree with the below or do you seem some problems? Are there other differentiating factors between the two printers that I should consider? The problem is, that even after I wrote all of this, I still cannot decide which one to get. Some days I am convinced I should get the Pro-1000 and other days equally convinced I should get the P800. Maybe the answers I get here will help settle it.
1. Size/Weight:
Pro-1000: 72,3 cm x 43,3 cm x 28,5 cm 32 kg
P800: 68,4cm x 37,6 cm x 25,0 cm 19,5 kg
Big difference especially due to weight which means the P800 can be handled easily by one person, while the Pro-1000 might need two.
Advantage: P800
2. Price: Where I live the P800 is about 15% cheaper than the Pro-1000.
(Small) Advantage: P800
3. Paper handling: P800 supports roll paper. Pro-1000 does not, and is limited to 24” length which means you cannot even use the full 17” width when printing a 3:2 photo. For me I think this is not so important, because you can’t buy 17 x 25.5 paper (I guess people use roll paper for this size prints?) and I would be happy with A2 as max size. I also don’t do panoramas. One small advantage for Pro-1000 is the vacuum feed, but I don’t know how much of a difference this makes in practice.
Advantage: P800
4. Image quality: About equal. There might be a small advantage for the Pro-1000 due to extra inks and gloss optimiser. However considering that the previous generation 3880 is being used by professionals to produce excellent quality prints, and that both P800 and Pro-1000 are even better, image quality should not be a differentiating factor.
Draw
5. Ink management: Pro-1000 has separate heads for PB and MB. How big of an advantage depends on the use: for someone who does a lot of printing and is able to batch prints so that they do not switch frequently, the wasted ink on the P800 would be a small % of the total ink used so it would not make a big difference. If someone switches ink frequently, or prints low volumes the % of wasted ink is bigger.
Also, if someone only ever prints on single paper type, there would still be an advantage for the Canon, because with the Epson you would still need to periodically swap inks back and forth so that the ink on the unused line does not get stale/settled. According to some comments I have read here, the Canon always uses both blank ink types (in different ratios depending on paper type) so there is no risk an unused ink line clogging when you only use one paper type?
Advantage: Canon
6. Maintenance costs/Life Expectancy: This is a tricky one. On the plus side for the Canon, the head is user replaceable and cheaper. Also redundant nozzles should mean more it is more resistant to clogging. On the plus side for Epson, the piezo technology means the head should last longer provided it is maintained properly (i.e. used frequently). There are a lot of should’s in the previous sentences and no real evidence to back them up though, so it is anyone’s guess about how these printers will behave in reality (especially how long will Canon's head last if it is used regularly but with low volumes?). My guess is that for heavy users the Epson might be better as the thermal Canon head has a limited lifespan by design, whereas the Epson should keep going and going. For light users the Canon might be better due to Canon’s traditionally better resistance to clogging, and cheaper replacement of the head if it does clog.
Inconclusive
1. Size/Weight:
Advantage: P800
Advantage: P800
Draw
Advantage: Canon
Inconclusive
