No pain no gain !
Skeeter Stevens
Forum Enthusiast
Texas, US
After my daughter was finished with her workout she was kind enough to let me practice. This is my attempt at a 3 light setup with black (actually blue blanket) background. Timer set to 10 sec so I could use spray bottle for some fx. processing done in LR.
nice job on both. i like first one because her arm's shadow has shown movement of flowing/blending into her side to belly smoother. well done with lighting to shine her muscles. my hat off to you.
cuong aka buzz
carl zeiss lenses do matter to me
zeissfolio.viewbook.com
Did you use a Beauty dish and 2 striplights?
1. excellent lighting
2. She is lovely
cuong aka buzz
Thank you for the comments and for looking!
Very well done with lighting and post. To be honest though, I think the model ruined the theme of the shoot. There might be better posing, etc in other shots, but these two are no go just because of her posing, physique and facial expression. Just my opinion.
Nice lighting. I like this one better as it looks like the water is coming off her. The first one looks like its raining.
https://www.flickr.com/photos/ap2380/
Excellent lighting once again!
A few minor suggestions:
1) You framed your daughter very centered. Cropping or shooting her slightly to the left would make for a more interesting composition.
2) She is doing a one-arm dumbbell curl. Ideally, the biceps would show better medially on the arm, i.e. if she were curling with her left arm at this body angle. The dumbbell also wouldn't be blocking some of her torso and the width (her back to extended DB) would fill the frame better and look more interesting.
2) If you want to photograph her curling with her right arm as you have, keep some space between the DB and her halter top. As is the grey hex dumbbell is touching the grey halter top. Having some abdomen showing inbetween the two would make for a better photo.
You did all the hard stuff well. Positioning your model differently is easy and quick.
'When nothing seems to help, I go and look at a stonecutter hammering away at
his rock perhaps a hundred times without as much as a crack showing in it.
Yet at the hundred and first blow it will split in two,
and I know it was not that blow that did it,
but all that had gone before.'
-- Jacob Riis (1849 - 1914)
Stay Well,
Pete K.
This is really good.
Can you tell us how you did the lighting?
TEdolph
