Actually, before you return the lens, please make sure you take a shot at higher ISO and a significantly higher shutter speed (at least 1/FL or better) in good light just to make absolutely certain you're not dealing with a camera shake issue. You shouldn't be seeing that issue with a tripod, but just to make sure, you should absolutely take that potential problem out of the equation.Seems pretty likely that you have a bum copy. I would likely contact the dealer and get it exchanged. That image is just as soft as the previous examples. It looks as if it could be camera shake as well, but if you are using remote on a tripod, it would seem less likely.
