But that is really important because Nikon 1 has been the king of mirrorless continuous AF for several years now.
I think some consideration must be given to the fact that the Nikon One system has a significantly wider depth of field at any focal length compared to APSC (or M4:3) which does help it a bit when it comes to getting accurate focus on a target - there's a bit more 'forgiveness' as the focus doesn't need to be quite as pinpoint perfect - it gets harder as the sensor gets bigger and the subject gets smaller. I think that's why Nikon's mirrorless always were touted as better overall with AF-C, even as some competitors in the M4:3 and APS-C fields started using OSPDAF or other methods to make more effective use of AF-C. No question it's good...but it was also a little easier to get that good coming from the smaller sensor...it's harder to get to that level of performance with the larger sensors and much shallower DOF and larger files with higher-res sensors. The Sony A6000 was fairly groundbreaking for mirrorless with its AF-C ability because it was delivering good speed and frame rate with continuous focus on that size sensor - seeming to come close to or match the Nikon 1 continuous focus speed and accuracy, though not the frame rate.
DSLRs have two major advantages over mirrorless: optical viewfinders and continuous AF. When mirrorless catch up with non-professional level DSLRs for continuous AF (and I personally think that the best mirrorless already have caught up) then all that is left is the OVF argument which is getting pretty weak.
I personally agree - for the last 2 years I've found myself wanting to use my A6000 more and more for BIF work, rather than my DSLR. It's just better - it picks up the initial subject faster, it continuously focuses faster and better with faster subjects, it's more accurate frame to frame with a higher hit rate, and of course smaller and lighter and therefore less fatiguing. I do wish there were longer focal lengths available - the A6300 may well have broached that problem a bit by adding near-native functionality on Alpha lenses. And the 8fps live feed EVF mode should make panning/tracking of subject in the finder easier for small and fast subjects - though honestly I never had much problem adapting to EVFs for that type of subject - I find the lag pretty easy to automatically adjust for, and I switch between an OVF and EVF daily.
The good news is that there has been significant improvement in AF-C functionality across the board with mirrorless systems - pretty much all have gotten better, some have gotten to entry-level DSLR levels, and some may even have a few advantages. None can quite compete with a semi-pro DSLR which has not only the excellent speed and tracking but also the myriad additional controls over the focusing parameters and tracking stickiness that the mirrorless systems don't yet have to that level. But all of this has developed in a pretty short time - really only in the past 2-3 years have mirrorless cameras started to seriously work on AF-C capabilities, and they're already putting some models in DSLR territory.
Justin
galleries:
www.pbase.com/zackiedawg
