The E-M5 (original model) does not have an electronic shutter. It has an electronically-timed mechanical focal plane shutter (as do most mirrorless interchangeable cameras except for certain of the Nikon 1 cameras, which ONLY have an electronic shutter - the S, J and AW models - though theirs does not seem to suffer the limitations of most others, or at least not to the extent of most others). The E-M5's mechanical shutter is a bit quieter than some focal plane shutters of its type - but on the whole, these shutters' sound comes as a nasty, loud surprise to people used to using compact digicams, which tend to have very quiet, interlens leaf shutters.As far as I know the EM-5 has an electronic shutter, right? Can anyone give me a link to see how the electronic shutter sounds? How silent is it? Any downsides for using the electronic shutter? Thanks.
The first cameras to have the electronic shutter facility (in the Olympus mirrorless range) were introduced with it already in place - the E-M5 Mark II and the E-M10 Mark II. Then the facility (with limitations) was added to the E-M1, and the just-introduced Pen F has the full version like the Mark II models.So, only the E-M1 has an electronic shutter (added through a firmware update)? I thought the E-M5 has the same firmware update which adds the electronic shutter...
In an earlier thread there seemed to be a credible statement that only the E-M5 mark II and now the Pen F have EFC, not the E-M10 mark II. So now I'm confused. Does the E-M10 mark II have a real EFC or not? Is there any credible source for whether it does or does not?The first cameras to have the electronic shutter facility (in the Olympus mirrorless range) were introduced with it already in place - the E-M5 Mark II and the E-M10 Mark II. Then the facility (with limitations) was added to the E-M1, and the just-introduced Pen F has the full version like the Mark II models.
The E-M10 Mark II has the options of 0-second Anti-Shock (EFCS) and silent (electronic) shutter as well as conventional shutter, as do the E-M5 II, Pen F, and the E-M1 after the firmware 4 update (the E-P5, E-M10 and E-PL7 have EFCS of the type that cannot be used in continuous drive mode - see below - and no silent/electronic shutter facility). However, watching the EFCS in operation on the E-M10 II, it does still run the first curtain at the start of the exposure, like those earlier models with the feature (and unlike the E-M5 Mark II, which doesn't - so far, the E-M5 II is alone in that, though I suspect the Pen F will be the same, as descriptions of its shutter sound make me think it uses the same unit as the E-M5 II). So in a way, the models with 0-sec Anti-Shock achieve a kind of virtual EFCS, though like the E-M10 II, the E-M1 after the big firmware update has gained the ability to use it in continuous mode too. It's confusing - Olympus seem to refer to the ability to use 0-sec Anti-Shock in continuous drive as "enhanced Anti Shock" but they apply the term to models which achieve that enhancement in slightly different ways.In an earlier thread there seemed to be a credible statement that only the E-M5 mark II and now the Pen F have EFC, not the E-M10 mark II. So now I'm confused. Does the E-M10 mark II have a real EFC or not? Is there any credible source for whether it does or does not?The first cameras to have the electronic shutter facility (in the Olympus mirrorless range) were introduced with it already in place - the E-M5 Mark II and the E-M10 Mark II. Then the facility (with limitations) was added to the E-M1, and the just-introduced Pen F has the full version like the Mark II models.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
The E-P5 isn't totally silent, ever, as it doesn't have electronic shutter. It does have electronic first curtain shutter, but of the type that still runs the first curtain physically before the exposure, so you get the sound of that too - it just doesn't use it for starting the exposure - that is done electronically in that mode. It is also has the type of EFCS that cannot be used in continuous drive mode.So, the EP-5, for example, is totally silent, or it has the sound from the first curtain?
Helen (as usual) has it well covered.Your explanation is consistent with I thought before. For true elimination of shutter shock it means that you need the E-M5 mark II or the Pen F.
The E-M5 Mk2 is really a very different camera to the E-M5, a long way apart in development, so it should be the E-M6 if things were to be named properly.I'd be interested in the E-M5 mark II if it became a lot cheaper. It takes a good bargain to make me upgrade from my E-M5 (mark I).
