Perhaps look for an old PS Elements disk?I upgraded to PSCC and it is 64-bit. Virtual Photographer will only run in a 32-bit program and I'm looking for something that will run VP as well as let me fade the applied filter. Are there any cheap (or free) programs that I should look into?
The Fade function in Photoshop was introduced at a time when layers, I believe, were unavailable in Photoshop.The filter I use always gets faded back to only 15% in PS. That's the missing feature with most programs.
I find that rather hard to believe, given that until just now, I'd never heard of it and that it costs about 1/10th. of the price of CS6 in the days when you could buy it.Photoline comes in both 32bit and 64bit flavours.
Virtual Photographer works perfectly well in the 32bit version. Even better, the 64bit version can send a layer/document to the 32bit version, the VP plugin can be applied, the result saved, and the image in the 64bit version updates automatically.
This way both 64bit and 32bit Photoshop plugins may be applied to the same file in a seamless workflow. Very handy: I know of no other image editor capable of this.
And Photoline happens to be very powerful as an image editor as well - about on par with Photoshop
(minus the video and 3d fluff).
I understand your reluctance. Up until three years ago I had never seen, heard, or read anything related to Photoline. The developers have little or no interest in advertising their image editor. And it has been around since 1995!I find that rather hard to believe, given that until just now, I'd never heard of it and that it costs about 1/10th. of the price of CS6 in the days when you could buy it.Photoline comes in both 32bit and 64bit flavours.
"It's good to be . . . . . . . . . Me!"(minus the video and 3d fluff).
Thanks.I understand your reluctance. Up until three years ago I had never seen, heard, or read anything related to Photoline. The developers have little or no interest in advertising their image editor. And it has been around since 1995!I find that rather hard to believe, given that until just now, I'd never heard of it and that it costs about 1/10th. of the price of CS6 in the days when you could buy it.Photoline comes in both 32bit and 64bit flavours.
When I first downloaded Photoline, I did not expect much. I had been looking for a replacement for Photoshop for quite some time, and every single time I was disappointed. Hardly any support 32bit per channel, Lab mode, proper curves, advanced blending, a mostly non-destructive approach, and so on.
Much to my surprise I learned at the time that Photoline supports all of this. There are things in Photoline which are just not possible in Photoshop: for example, the opacity for a layer can be set from -200(!) up to +200. As many layer masks and grouped layer masks can be added to a layer. Adjustment layers can be applied to layer masks. You can have layer masks affecting other layer masks. Layer effects can be applied to layer masks even!
Layers, layer masks and layer groups can be virtually instanced, and re-used across the layer stack. This means one mask may serve as the base for many others, and when the original is changed, the others update in real time!
Photoline supports pages, external file layers, "smart objects" (smart objects in a PSD are kept intact - even the Illustrator content can be edited DIRECTLY in the latest betas of Photoline!), a non-destructive liguify layer (which can be stacked and "reversed" in effect with the opacity slider), adjustment layers can be combined in a "super" adjustment layer for easier layer management, a really nice vector selection tools, full vectors (which, unlike Photoshop, render at the highest resolution or at the document's native pixel resolution), HSV/HIS workflow, and so on, and so forth.
Transformation of layers is by default non-destructive, unlike Photoshop (first one has to convert to a smart object).
The biggest workflow enhancer for me was the fact that layers in THE SAME layer stack can have ANY colour mode, bit depth, and size. No longer is it required to switch image modes when I wish to create a CMYK or LAB version. The background layer decides on the output. This means I can switch to a CMYK version, and switch back to RGB WITHOUT losling ANY information in my layers.
It also means I can add a curves adjustment layer, switch that curves adjustment to Lab, HIS, HSV, RGB mode on the fly, and there is no need to switch image modes again.
And, as I stated before, the external app link is quite unique and incredibly useful to have. I can send vector layers to InkScape, edit them with more elaborate vector tools, and then save. The result updates in Photoline, and I can continue editing until I am done. I can send bitmap layers or the entire document (if supported in the external app) to other bitmap tools, and use those as "plugins". Super handy.
Are there caveats compared to Photoshop? Yes, of course. There is no animation, no 3d, and for digital painting I would look elsewhere. The one thing I miss most is the Refine Mask option in Photoshop. Arguably the RAW processing can see improvements. I use Krita for digital painting (superior to Photoshop for this type of work in my opinion), 3dCoat for 3d work (again, no comparison to Photoshop), and a combination of DxO, Raw Therapee, and Photoline for RAW developing. For animation and video, I would never use Photoshop - far too primitive and limiting. I use applications such as Blender, Fusion, DaVinci, TVPaint, and other tools for that type of work. Which allow me to work "Adobe free".
There are many things Photoline does better than Photoshop. And other things are missing. As always, there is no single perfect application, and it depends on one's individual workflow whether it hits the requirements.
I see you've also got PSP8 ??Lyle,
I just tried to download the stand alone program for Windows 7 and every time I import a photo, I get lots of error messages and it won't work. Do you know why? I am using PS CC
Melissa
Adobe Photoshop CC 2014
http://upload.pbase.com/mnewco
You can still download the PS CC 32-bit version, but it you have to download manually since you are running on a 64-bit OS. Here is the link:I upgraded to PSCC and it is 64-bit. Virtual Photographer will only run in a 32-bit program and I'm looking for something that will run VP as well as let me fade the applied filter. Are there any cheap (or free) programs that I should look into?
