Richard Spangler
Leading Member
- Messages
- 968
- Reaction score
- 302
What I want to do is use flexible point AF but if it isn't hitting what I want Id like to be able to turn the focus ring to override the AF and grab the shot. Is this possible?
Not sure if this what you're looking for... but it first gives you AF then drops you into MF if you turn the focus ring. However, it may only work on FE lenses... doesn't work on my adapted A mount lens.What I want to do is use flexible point AF but if it isn't hitting what I want Id like to be able to turn the focus ring to override the AF and grab the shot. Is this possible?
The default setting for the af/mf switch button is to toggle between af and mf when the switch is set to af/mf
Select "DMF" (I think it stands for Direct Manual Focus). I keep my camera in this mode most of the time.What I want to do is use flexible point AF but if it isn't hitting what I want Id like to be able to turn the focus ring to override the AF and grab the shot. Is this possible?
Well, if you want to go through the menus, it's under camera-menu panel 3, Focus Mode. Scroll down for DMF. But most of us have Focus Mode assigned to a button or the Fn menu.Thats what I'm looking for. How do I set it?
Yes - that technique is called "back button focus". Brian Smith has written a lot about this here and on his blog. HIGHLY RECOMMENDED!Is there anyway to set the camera to MF as soon as I start turing the focus ring rather then pressing the button?
If using AF-S, I keep the shutter button half-pressed and simply adjust the focus, then fully press to shoot.What I want to do is use flexible point AF but if it isn't hitting what I want Id like to be able to turn the focus ring to override the AF and grab the shot. Is this possible?
DMF mode if you have a native lens. Sony should set this as the default because many never even try it.What I want to do is use flexible point AF but if it isn't hitting what I want Id like to be able to turn the focus ring to override the AF and grab the shot. Is this possible?
