Image stabilisation question
KAllen
Norwich, UK
Hi,
I'm wondering about the in camera 5 axis stabilisation and built into the lens stabilisation.
If I use a Canon L lens with stabilisation via a metabones would I get the lens stabilisation plus the 5 axis?
If so is it better or worse having both switched on, I could see a conflict between the two if its possible.
Thanks.
Hi,
5-axis is only available when using select Sony OSS lenses.
No. With a Metabones, you can choose between IS only, IBIS only or no stabilization at all. Never in combination since the Canon lenses cannot turn off the axes the sensor takes care of. Sony OSS lenses can do this.
I suggest you check out the Metabones site. They are pretty thorough with what you can and cannot do with their adapters.
Hi,
Actually ALL 8-pin Sony lenses can get 5-Axis Image Stabilization on a7-series Mark II cameras.
Sony OSS E-mount lenses get Pitch & Yaw stabilization from the lens and X, Y and Roll stabilization from the body.
Sony E-mount without OSS and 8-pin Sony A-mount lenses get all 5-axis IBIS from the body.
NOTE: 5-pin Sony SAL 16mm F2.8, SAL 20mm F2.8, SAL 28mm F2.8 and SAL 500mm F8 lenses only get Pitch, Yaw and Roll stabilization when attached using a Sony LA-EA3 or LA-EA4 adapter.
Yes, that's true beginning FW 0.41.
I strongly recommend turning off IS or VR on third-party lenses and allowing the a7-series Mark II body to take care of it. Except for the Canon EF 100mm f/2.8L Macro IS USM, Canon lenses only provide 2-Axis OS, but a7-series Mark II bodies can provide 3-Axis IBIS.
Not only does this provide an additional axis for roll-stabilization but IS and VR suck lots of power away from AF when using Smart Adapters so turning it off on the lens will provide better AF.
There is no conflict with Sony lenses as the system is designed to work together, but I recommend turning off OS or VR on third-party lenses for the reasons listed above.
There is a full description of how the system works here: Sony a7II Review
Brian Smith
Sony Artisan of Imagery
Brian Smith Pictures
Hi,
What is the status of the SEL55210 and SEL1018 on the A7RII? I know they earlier had OSS disabled entirely when used on A7x bodies. I suppose they work just as the lenses that lack OSS?
Brian Smith
ok, so it is recommended that the IS on the Canon lens be off. However if using a zoom (say Canon 70-200L IS) lens, using the IBIS feature is going to be a pain cos there is a need to dial in the focal length manually each time I zoom into a subject??
You don't have to dial in the focal length manually because the Metabones Smart Adapter provides the lens focal length information to the camera.
That would be the Metabones, but I guess other (cheaper ones) like Viltrox & Fotodiox will not be able to do so.
