Because some strobes only have PC port and it is convenient. You can get a cord/adapter to do with with the hot shoe but it's a but more expensive and bulky.Wikipedia says flash synchronization is achieved by either via a PC socket or a hot shoe... so why there are the both things on this camera?
Just in case the OP isn't distinguishing between strobes and speed-lights.Because some strobes only have PC port and it is convenient. You can get a cord/adapter to do with with the hot shoe but it's a but more expensive and bulky.Wikipedia says flash synchronization is achieved by either via a PC socket or a hot shoe... so why there are the both things on this camera?
Good point, the terms get used pretty interchangeably these days.Just in case the OP isn't distinguishing between strobes and speed-lights.Because some strobes only have PC port and it is convenient. You can get a cord/adapter to do with with the hot shoe but it's a but more expensive and bulky.Wikipedia says flash synchronization is achieved by either via a PC socket or a hot shoe... so why there are the both things on this camera?
Studio strobes usually connect to the PC socket and speed-lights to the hot shoe. Studio strobes are also normally controlled with manual power settings, the PC connection which can just fire the strobe is fine. Older hot shoes would only trip the speed-light but as TTL flash came along the camera needed to modify the speed-light set-up on the fly and contacts were added to the hot shoe for these controls.
True, but a few spare sets of AAA batteries takes up way less space in the bag than a 20' PC cord.When the batteries run out in your wireless triggers a sync cable on the PC socket will still work - it doesn't need power.
Not sure I understand this one. Why would a sync cable be the only option? From my experience, my Cactus V5 triggers have never misfired unless I bumped the channel selector, which is a 2 second fix. I've found these triggers to be rock solid reliable in all situations.The PC socket is usually (not always) more reliable than the hotshoe PC gizmos.
A lot of group shoots the only option you get to trigger the strobes is a sync cable. Oh, sometimes you can get your wireless triggers to work, but don't count on it.
