N
neil holmes
Guest
Back again, I see....
I use primes over zooms.....I will take the Canon 17mm F4 TS-E, the Sony Zeiss 55 1.8 and the Canon 135 f2 L for my needs.....and when I DO want a zoom, the Sony FE kit lens on a FF camera gives great results for the price that I would still take over that 2.8 zoom on M4/3....others will differ.
If I used zooms, I would take the Sony Zeiss 24-70 over both the FE kit lens and 12-40 2.8 M4/3 zoom.
The Canon 135 also does double duty on my GX7 for a different angle of view...same with the nice little Canon 40 2.8 STM
yes, the Pro zooms are sharper across the frame but I think that in the centre the cheap FE kit lens may well be sharper (as shown on DXO)....I don't use it much but it is a very nice lens to have and great value. The Sony Zeiss 24-70 f4 is sharper again (other than the centre maybe) and sharper across more of the frame than the FE kit lens. ......the FE kit lens rates as sharper in the centre than the Sony Zeiss zoom at DXOmark but is not as good away from the centre.
http://www.dxomark.com/Lenses/Compa...A-OSS-on-Sony-A7R__1244_917_1233_793_1253_917
I think M4/3 kit lenses are nice to have as well and also good value but I will take the FE kit lens over an M4/3 kit lens any day and prefer the results from the FE kit lens (especially on an A7s in low light too) over the pro zoom and an M4/3 camera.
You could buy an A7 and a Sony 55 1.8 for less than the price of a E-M1 and 42.5 1.2....so it is all relative.
My 55 was around $850 (Australian.....certainly a lot less than $1000 US for a fantastic lens.
My two Canon TS-Es were both a lot more.
My 135 was dearer than my 55.
My 85 1.2 FD L is good enough that I likely wont get a Zeiss Batis 85 1.8 or Mitakon 85 1.2 in E mount or EF 85 1.2 L ii all of which will work well for me on the Sony's.
You can put together a nice kit with ANY system.
Now, your turn......what kit are YOU using?
Care to show any shots from both of them (I am sure you must have both right?).The Oly 12-40mm F/2.8 is a significantly better lens than any of the Sony Zooms.
LOL, the only Sony zoom I have is better than my only M4/3 zoom....and even though it is slow, it is actually has greater DOF control at 28mm than the 2.8 Pro zooms.....and at its longest at 5.6 is no worse.Sony prime are great, but their zooms have small apertures and are garbage.
I use both M4/3 and an A7 and an A7s.....the GX7 is not up to the A7 in low light and the A7s is better than anything.The Sony is a bit better in low light which is obvious, but when comparing with the good M43 F/2.8 zooms vs the lousy Sony F/4 zooms, they are near equal. (Some Sony owners will try to tell you otherwise.
When have you EVER been honest? Even your name suggests otherwise!Others like me will be more honest
I think people by all means should read reviews and if possible try what they can for themselves......M4/3 can be very good....so can Sony. The DXOmark link above is a great place to start.- read the reviews)
MY three most expensive lenses are Canon, THEN comes a Sony 55 1.8 (one of the best AF lenses available for any system) then a few others and then the FE kit lens.What will really kill you with Sony is lens prices. Currently the FE auto-focus lenses average around $1200 each. A prime that is only F/2.8 like the FE 35mm costs a whopping $800. The Panasonic 20mm F/1.7 is less than half its price, half its size, and gives you more than a stop of light when wide open.
Well I would use my Canon mount 150 2.8 Sigma......which I also use on my GX7 but mainly my 135 f2 L Canon on both.And if you want a long lens, forget about Sony. That's when they start to get HUGE and super pricey. With you OMD, you could get the Olympus 75mm F/1.8 whcih Sony has nothing close.
My 150 was around $600.And if Sony did make a 150mm F/2.8 or even F/3.5 prime it would cost close to $2000 going by the high prices of the rest of their lenses.
Now that depends on what sort of kit you want......Overall you will find you can get an EM5 II and several great lenses for under $2000. For the Sony expect to pay $4000 or more. Ouch.
