Hello everyone. I am starting a thread to ask you guys about your experience with the Canon EF-S 17-55 f/2.8 IS USM, specifically its Err 01 issue. I just came from a trip to Japan (operating temp was between 3-14C) and the lens just malfunctioned from the first to the last day of my trip...i was not able to use it. Every time I mount it and try to use it, Err 01 appears with the check lens contacts message. The odd thing is that I checked all of my lenses 2 weeks then 2 days before the trip (I live in the Philippines and the operating temp is about 26-33C) and all worked fine. Upon arrival in Japan...the 10-22, 50 and 85 mm leneses (all Canon) worked flawlessly. The more peculiar thing is that the 17-55 works when I am at my heated room (around 25C) but not outside where I shoot.
I've brought the lens before to Korea and New Zealand with the same cool temperatures and it did not had any problem. I did not drop it or scratched/played with the contacts. Since my other three lenses worked, I am also pretty sure that it is not the camera body (60D).
What do you guys think? Does temperature affect the 17-55? Do you guys think I should have it serviced? Problem is that I am now back to my country and it works again. I will be going to Hong Kong in January with temperatures of about 12C and I am seriously concerned that it will malfunction again. Any help would be greatly appreciated. Thanks!
