I was really upset about Jerky motion issue in AX100, I searched internet, there are lots of discussion. the answer are using right shut speed ( ie using ND to slowing down shut speed to frame rate*2) and slowing down the panning/zooming speed, higher frame rate with low resolution, etc. nevertheless the problem still happened.
Just now, I bring the portable HD to TV shop, and try play video in different TVs, Samsung TV perfectly play it, sony a little bit jerky issue, and most of rest TVs have serious issue. I suppose the Samsung or sony have kind of motion compensation technology to handle the issue. So far I'm not sure if the external player could solve this problem or not.
Correct me if I'm wrong. sorry for my poor english.
Share a sample clip that has this problem online that we can download and test. We could then give you some feedback about it.
Let us know the frame rate, shutter speed, and bit rate that were used when recording the clip. And in your tests, are you working with original files straight out of the camera, or files that you have edited and rendered yourself? Do you see the same issues when you view the videos on your PC?
There is nothing at all wrong with the video produced by the AX100. But it does produce higher resolution and higher bitrate video at slower frame rates, just like all of the other current consumer 4k cameras do. So you need to be aware of the limitations that imposes. And it does have a fairly long telephoto zoom range. Most image stabilization systems on cameras cannot hold such long telephoto shots real steady.
It is not stabilization issue, it seems that tripod doesn't help at all. clip shoot in wide angle, 4k/25f, no edit. I do observe the jerky issue in PC, I believe player in PC do not perform frame interpolation.
Struggle with the dramatically higher bit rates of 4k video. I do not believe that you are experiencing anything other than what one would normally expect to encounter in playing any 4k/25p video.
I don't have a PAL AX100 myself. Mine is NTSC, and I thus do all of my recording at 4k/30p at 100 Mbps XAVC-S. And I see nothing like what you describe. What bitrate option are you recording at? What firmware revision is your AX100 at? Have you ever gone into setup and checked the version number? Do that, if you have not already done so.
If you want to get to the bottom of this, then please follow my earlier suggestion of posting a short video clip that illustrates what you are experiencing that we can downloaded. Then other people here could examine the file, and see if we can duplicate your reported problems.
the firmware is 3.00, if I remember correctly, however I use 60m bitrate to shoot, because many mentioned no obvious difference.
I upload a typical jerky/flicker video (original mp4) to chinese popular cloud service
http://pan.baidu.com/s/1c03AY8C
sorry, it is in chinese, you could click download icon in up right, then in the pop up box click the right button, meaning normal download, the file is C0219.mp4 (73.8 MB) I shoot it in running tram.
the second scene is even more normal ie panning cause jerky/flicker issue
http://pan.baidu.com/s/1ntKnCoT
the file is C0258.mp4 (83.5 MB)
It would be great if you could check these files.
