PNad
Leading Member
Does this entirely remove reflections? Rosco makes some polarizing gels and some glasse's coating are really really reflective, would using the gels with a circular polarizer on my lens remove it?
Are you photographing glass or a glass covered object.Does this entirely remove reflections? Rosco makes some polarizing gels and some glasse's coating are really really reflective, would using the gels with a circular polarizer on my lens remove it?
I dont want to buy a $200 roll to try the portrait experiment, this is why I asked in this forum. I want to know if it will remove reflection from people's glasses.Are you photographing glass or a glass covered object.Does this entirely remove reflections? Rosco makes some polarizing gels and some glasse's coating are really really reflective, would using the gels with a circular polarizer on my lens remove it?
In general yes cross-polarization will eliminate 99% of your glare issues. Cross polarization means that the polarizer a are oriented so that the polarization axis for the gel and the filter are at ninety degrees to each other.
Smooth Glass, because it is a very efficient reflector, will still have direct reflections of light sources.
Want to try an experiment? Use cross polarization when shooting a portrait.
Im a big fan of this lighting setup. Yes it was lately popularized by Peter Hurley and im straight on using "his" technic, but in the end thats what we all do anyway (using someone else thing). Back on topic, this is 3 softbox aimed directly at the face (for this photo I actually used a beauty dish, ence the round bottom catchlight) The problem is, some eyeglasses get some heavy reflection from the bottom light, and I really love that triangle catchlight. So I thought of putting a polarizing gel on the bottom softbox.It will work for the glasses... I don't know if a lack of sheen from skin is an issue, that seems like it would be ok to me. But I haven't used it for portraits; it will also cost about 3 stops of light.
https://www.flickr.com/photos/skersting/
try it and tell me what you think.its not like using matte makeup, it's more like the light penetrates the skin.SKersting66 wrote: I don't know if a lack of sheen from skin is an issue, that seems like it would be ok to me. But I haven't used it for portraits.
I think it may be more about the specular hightlights. The cross polarization probably removes it and it ends up looking super flat?try it and tell me what you think.its not like using matte makeup, it's more like the light penetrates the skin.SKersting66 wrote: I don't know if a lack of sheen from skin is an issue, that seems like it would be ok to me. But I haven't used it for portraits.
If you can't get the light into a position where reflection off of grasses isn't a problem you can try raising the earpieces a small amount. This tips the lenses down a bit and changes the angle of reflection for a light.
To get the best results in reducing polarized reflections you want to use crossed linear polarizing filters.
I suggest you see if your local library has a copy of Light Science and Magic. The section on polarized reflections starts on page 41.
Amazon.com - Light Science and Magic, Fourth Edition: An Introduction to Photographic Lighting (9780240812250): Fil Hunter, Paul Fuqua, Steven Biver: Books
Being that I don't really do portraits, I'll take your word for it... I've seen the effect on plants.try it and tell me what you think.its not like using matte makeup, it's more like the light penetrates the skin.SKersting66 wrote: I don't know if a lack of sheen from skin is an issue, that seems like it would be ok to me. But I haven't used it for portraits.
If you use a linear filter on the lens it will (potentially) adversely affect AF/viewing.To get the best results in reducing polarized reflections you want to use crossed linear polarizing filters.
If you only cross polarize one light, then I don't think the effect on the skin will be extreme. But yes, if you remove the reflection from the glasses it will also affect the catchlight.
A common trick is to simply remove the lenses from the glasses... this also eliminates the face-line "jump" that can happen with many prescriptions. You can always ask them to bring an old pair to work with if they have suitable ones.
BTW, the reflected light from glass is already polarized, a CPL should be able to remove much of it. (And it would also affect the other reflections in your one filtered light setup idea).
I am 100% confident that a single CPL on a lens wont remove direct flash reflections. And to support my point, heres a behind the scene with product photographer Rob Grim:Yes, anytime light is reflected from an absorptive surface (water,glass,paint,etc) it is polarized. In fact, all light is polarized to some minor extent simply due to passing thru the air. Surfaces that do not absorb/pass any light (metal,mirrors) do not add additional polarization. How much the light is polarized will determine how effective a CPL is (you may not be able to completely remove the reflections...and it will affect the catchlights as well).
Because he's using the gel on a secondary light in order to get it to match the other light the CPL is adjusted for... that's why he has to adjust/turn the gel on the light, and not the CPL.Why he would bother using the gel on the strobe if a single CPL would work?
