Dave Sanders
I would disagree. I love my A7R but I'm not going to fool myself about what it can and can't do well. It's AF is average in good light. In anything but, it is poor compared to any camera with a modern AF system. I've been shooting digital since my Canon 10D in 2004 and my A7R has the overall slowest AF I've ever used. It is, however, very accurate. But it is what it is. I'm not a particularly demanding AF user so it's fine for my purposes, but one should know what they're getting into. If your subject is decently lit, it will be quick enough and very sure.No - it is not "very poor". It is actually very good but it is not excellent (as defined by semi-pro and up DSLRs).My major issues:Hey there, I am seriously considering picking up an A7R body and was wondering what the worst features are about it? What should I know and what kind of deal-breaking issues to people have with it? The A7Rii is not in consideration due to cost.
1. AF system very poor (the worst of any autofocus camera I have ever used by some margin).
The A7RII on the other hand...
The A7R suffers from shutter shock. It will negate any benefit of the high MP camera within the affected shutter speed range. It is generally better handheld, I find. I'm mostly on a tripod at long shutter speeds, but I get noticeably sharper photos with longer lenses in the affected range with my D810 than I do with my A7R. The key being 'in the affected range'. I have found the shutter shock issues a bit random, I'll have 4 or 5 in a row affected, then get one that isn't.I rarely have problems with OOF images when the proper shutter speed is selected. Are my handful of OOF images due to shutter shock? Don't know but it has not impacted me in any way.2. Shutter shock - on all lenses in the 1/10 - 1/200s range. Worst at around 1/60-1/120. Obviously magnified for longer lenses, but I've seen it pretty clearly even at 35mm. The effect however never really reduces the resolution much below the A7, so in many respects it's not worth worrying about, and it is absolutely less of an issue than mirror slap in a DSLR.
Again, something that I think doesn't get noted enough, from my experience it isn't nearly as prevalent hand held.
Agreed. I can generally get used to any camera and the A7 and A7R are no different. They are very, very easy to customize and there are a ton of programmable function buttons. I can access anything I need very quickly. The grip isn't perfect, but it works. Like all good tools that serve one well, you will find you grow quite attached to how it functions.I have no problems.My minor issues:
3. Poor ergonomics. (Personal thing YMMV of course.)
Not such an issue for me in most cases, but yes, it's loud. When people say 'wow, that's loud' I like to say 'no, it's manly' ;-)Very true and a real problem for me in many cases.4. Loud shutter.
While I have my A7R on a tripod a lot of the time, I agree, it works very well as a hand-held camera. The tilting screen allows for a lot of great angles and at shutter speeds above 1/200, I've never had any problems using all sorts of terrible hand held technique and still getting great shots. The 55/1.8 begs to be shot wide open so lots of the time I'm way out of the danger zone for shutter shock.My A7R has never been on a tripod and all my Sony lenses are AF.The A7II and A7RII don't suffer from 1,2,4 and improves 3, and have IBIS!
I would choose the A7II over the R unless you are planning on shooting almost exclusively on a tripod with MF lenses.
Agreed. Though I've not shot with the A7II, I found my A7 worse at every ISO. It's noisier than I expected, especially in the shadows if you don't nail exposure. With the A7R you can make quite rude exposure mistakes and pull shadows to your hearts content in post.I have no problems producing razor sharp images when the proper exposure parameters are in place.
The A7II image quality is not the equal of the A7R no matter how you slice it.
I paid $1500 for my A7R on closeout when Sony killed their Canadian retail operations...and man, it's turned out to be a killer bargain.
