It may be a good camera.
Typo.They mentioned IBIS - is this real or typo??
Vlad
It isn'tHe was confused. Turning OIS on/off using system menu doesn't mean that IBIS is built in.
Would be great if it is.
The higher consciousness is colorless, odorless, and without form. Therefore, it's prudent to not judge others based upon their physical qualities.
UhmThat review states:
"On the front of the Panasonic Lumix DMC-G7 is a tiny focus-assist and self-timer indicator lamp, black lens release button, metal lens mount and a generously-sized rubberised hand-grip with a sculpted indent for your forefinger, which is large enough to effectively aid your hold on the camera. Optical image stabilisation is built into the camera body, with the 14-42mm II kit lens lens that we tested the DMC-G7 with lacking a physical OIS switch. Instead it can be turned on and off through the DMC-G7's menu system. When enabled, the Panasonic Lumix DMC-G7 automatically compensates for camera shake, which is a slight blurring of the image that typically occurs at slow shutter speeds when the camera is hand held."
I think he means that there is no switch to turn on/off the OIS on that lens, and that the SWITCH to do so is in the camera, not that it actually has some form of IBIS. Would be sweet if it did have the GX7's IBIS though.
"Optical image stabilisation is built into the camera body"
You can´t built an optical stabilisation system in the body
IBIS works by moving the sensor.
So that sentence is only telling about his incompetence.
Incorrect. It matters not whether the stabilisation is lens or sensor shift based. IBIS is a form of optical image stabilisation regardless."Optical image stabilisation is built into the camera body"
You can´t built an optical stabilisation system in the body. IBIS works by moving the sensor. So that sentence is only telling about his incompetence.
--Incorrect. It matters not whether the stabilisation is lens or sensor shift based. IBIS is a form of optical image stabilisation regardless."Optical image stabilisation is built into the camera body"
Well I'm yet to experience that myself but I'm happy to accept we've been reading different reviews.I get the point here (even though this is semantics). In reviews, they tend to distinguish between "optical" stabilisation (where they mean moving one or more lens elements) and sensor shift stabilisation where the glass is fixed and the sensor moves.
