Actually it fits the GM5 just fine. It's even listed as a compatible model on the Panny website. In all the ways that are relevant here the camera dimensions are the same.No the cameras are different dimensions entirely
GM5: 99 x 60 x 36 mm
GM1:99 x 55 x 30 mm
Even if you did screw it in the grip would be 5 or 6mm closer to the body in each direction.
Again, it's perfectly compatible. The width of both bodies is the same and the tripod mount is in the same position. The extra 5mm depth accounts for the protrusion of the EVF, that's all.I'm sure it fits, that wasn't the issue of contention, I was just saying the dimensions of the camera are largely different and while it would screw in the grip would be in a totally different position. 5mm here and there does count.
I'm not sure why, but you're not really listening.Clearly I have demonstrated that they're not the same size actually... You can verify the measurements I've posted above the GM5 is meaningfuly larger.
No, I don't own the grip. But Panasonic have posted plenty of marketing pictures that show the grip attached to the GM5. For example: http://panasonic.jp/dc/gm5/lens_accessory.htmlDo you have the gm5 with the grip? If so could you take a picture?
Clearly some demonstrations can be clear yet incorrect! ;-)Clearly I have demonstrated that they're not the same size actually...
I had both the GM1 & GM5, they are the same size as far as the grip, it would fit perfectly.Clearly I have demonstrated that they're not the same size actually... You can verify the measurements I've posted above the GM5 is meaningfully larger, so I'm not sure where you're getting the idea from that its not.
