vett93
My Sony A7II's kit lens has a blue-ish color cast and the Tamron 28-75 F2.8 has a yellow color cast. What is a good way to get rid of such color cast?
That is good advice, however if the lens has a colour cast problem, which varies according to the aperture used, then he'd have to profile that lens for each aperture he's likely to use. A much more practical and better solution is to apply a flat field correction. Unfortunately LR doesn't have that feature.[...] Best is if you shoot the Passport in each lighting condition, then you can create a color profile for your image sensor and lens for the lighting conditions and set the WB using the gray patches on the Passport.
Thanks for the post. Not an issue for the lenses I have but good to know!Just learning the term flat field correction, these are two of the top Google results.
http://labs.adobe.com/technologies/lightroomplugins/
http://tobinators.com/blog/index.ph...e-lenses-and-lightroom-flat-field-conversion/
Yes, but it does not get rid of color cast.Do you correct your pictures in LR using the lens profiles provided?
Create custom profiles for both lenses. Use X-rite ColorChecker Passport or similar.My Sony A7II's kit lens has a blue-ish color cast and the Tamron 28-75 F2.8 has a yellow color cast. What is a good way to get rid of such color cast?
