Yes, most come with them now I think.Rich, you can use small rubber O rings inserted around the straps lugs before attaching the strap metal rings. They will protect your camera against wear caused by the metal rings.
Except for my own stupid mistake, it was really pretty easy. The English in their instructions is a bit tortured, but the pictures on their site (which is where the install instructions are) are clear enough. It's a little scary going in for the first time, but once you've done it, you realize it's really quite simple and I wouldn't hesitate to do it again. It should have been blatantly obvious to me that I was pulling the little wire clamp out rather than the screen, but somehow it wasn't. I'm quite sure you wouldn't make that mistake twice! And it was a mild pain in the rear to get it back in place, but if I could do it, it's not like it's a highly technical exercise! Most half-way observant people wouldn't make that mistake...Thanks, Ray. I've been kicking the idea around, but hesitant to jump in there and maybe do what you did (or worse). Did you get instructions with the screen that were helpful? The website makes me nervous about anything they print in English.
Glad it is working for you. I have a couple of questions.I received and fitted my focusingscreen.com Df S-type focusing screen (made from the Canon Ec-S high-recision matte screen).
Ovbiously the viewfinder is really dark compared to my Nikon F, F2, and the contrast is visibly softer than the stock screen, but focusing accuracy seems to be superb. Depth of field is accurately shown for fast lenses (1.4, 2.0) and it's especially useful in good light.
This screen highlighted the fact that Nikon still didn't shim the focus screen in my Df accurately (still had a tiny bit of back-focus, masked by the deep field shown by the stock screen), and I had to add another shim, but manual focusing is now surprisingly accurate.
All my ad-hoc tests shooting a fast 50mm wide open, focusing on e.g. a portrait's eyelashes far away from the centre of the frame, appears spot-on. I'll post some examples later on.
It's wonderful to be using one of the great 50mm lenses in history - the Nikkor-H.C. 50mm f/2 from the 1960s - on a sensor with the dynamic range to match black and white film for all intents and purposes, and to be able to focus it accurately.
This camera (especially in black) is much prettier in person than what it appears in pictures. I think it's a severe mistake to put the stupid locks on the dials - as opposed to just making solid, stiff, dials like e.g. the Fujis and Leicas have - but its a mean, compact, image-making machine otherwise.
Because it's a special high-precision, fine-grained matte screen that shows the actual DOF of a lens at f/1.4, unlike most screens. I can visibly see the difference when I stop a f/1.4 down to 2.0. The stock Df screen shows almost no difference between f/1.4 and f/2.8.Glad it is working for you. I have a couple of questions.
- the S Type is a full matte screen, no split prism, correct? Why did you choose this one?
Most of the split prism screens have a matte area similar to the stock Df screen. Brighter and more contrasty, but less accurate - only showing f/2.8 DOF. The screens in my old F and F2 are perfect though, don't know why such heights can seemingly never be achieved again, 50 years later?From reading above, S Type can focus anywhere on the screen, are the screens with the Split prism, say the K3, harder to focus in non central (away from prism) areas, do you know?
I certainly can. Difficult to explain, but the Ec-S screen is definitely dimmer, and less contrasty, than the stock screen. But it's really accurate, showing the precise location of the focus plane. Requires good eyesight, and a properly calibrated (shimmed) screen though.Just how dark are we talking re the screen, compared to stock? Can you still see clothes textures and colors, landscape flowers and leaves etc easily in twilight?
My pleasure!Thank you!
Lol.... for sure. When my D610 arrives, I will see how my MF lenses do and if I really enjoy the results, I surely will try the S screen for regular use.Because it's a special high-precision, fine-grained matte screen that shows the actual DOF of a lens at f/1.4, unlike most screens. I can visibly see the difference when I stop a f/1.4 down to 2.0. The stock Df screen shows almost no difference between f/1.4 and f/2.8.Glad it is working for you. I have a couple of questions.
I remember this screen from they days when I used Canon (up to 2008), and it's great.
I need to adjust the shims in mine - it's out by a tiny amount, front-focusing by about 10cm at a distance of 10m with my 100mm f/2.0. This screen is so accurate, you can actually see that, whereas you wouldn't with the stock screen.
Give it a try. If you don't damage your stock screen when you take it out, you can always put it back![]()
Much thanks, thank you for the detailed explanations!!My pleasure!Thank you!
No impact on AF in either direction. Except you might not use it as much...if i change screens, does it negatively affect the AF shooting experience?
Wish I'd seen that before I tried doing it. I think I was anticipating it being much more difficult than it was, and so I MADE it much more difficult than it needed to be. I also used the various tools they provided with the kit to open the little metal clip and to remove/replace the screen. I can see doing it by hand is just as effective and probably easier...I created a video of me changing my Df's focusing screen. It only takes a minute or so. It's very simple.
That's a great help. It really does look easy. Thanks.I created a video of me changing my Df's focusing screen. It only takes a minute or so. It's very simple.
I've heard that it will impact metering w/ flash pretty significantly. I don't know if that's true or not. With a Df, that would mean if you were using an external flash.if i change screens, does it negatively affect the AF shooting experience?
I chose the K3 (don't have it yet though it has been shipped) because I think the split will help with low light and it covers a larger area on the viewfinder. ...and it is a Nikon focus screen.Thanks again. I narrowed it down to the EC-A and K3 screen. The microprism will help me most. I'm not sure if the split screen on the K3 will aid for double confirmation. thoughts on that?
