Canon 200mm f/2.8 FD vs EF comparative lens test with a Sony A7ii
I was somewhat disappointed with the purple fringing of the Canon nFD 200mm f/2.8 v2 lens in high contrast situations(eg photos with dark trees/birds against the bright sky) at wide apertures. Unfortunately Canon never made an L version of this lens, although the ordinary version is beautifully made.
I decided that I couldn't live with the purple fringing and got hold of a Canon EF 200mm F/2.8L USM II lens to compare against the FD. The FD was released in 1982 and the EF in 1991 with a minor facelift to a version 2 in 1996.
Key similarities and differences...
Both lens have a 72mm filter thread, an 8-blade aperture and a minimum focus distance of 1.5m. Both lens are well constructed, despite not being an L lens, the FD feels equally well built, compared with the FD.
Other physical differences:
a) The FD has 7 elements in 6 groups(none special); the EF has 9 elements in 7 groups (including two ultra-low distortion elements).
b) The FD combo is about 18% lighter at 840g vs 1012g for the EF (including adapters).
c)) Fitted with adapters (cheap Fotga for the FD, Metabones IV for the EF), both lens are a similar size as shown in the pic below, though the EF's hood (pictured next to the lens) adds considerable bulk.
d) The clever screw-out lens metal hood of the FD is a more convenient design than the reversing plastic hood of the EF.
f) The FD is purely manual focus, whereas the EF is notionally autofocus with the Metabones, but the AF is too slow and too inaccurate to be of any use on a Sony camera
g) The FD has a larger focus ring and is designed for manual focusing, whereas manual focusing is secondary with the EF
h) The FD plus dumb adapter does not convey EXIF info to the camera, whereas the EF and Metabones passes both aperture and focal length to the camera and the A7ii uses this info for the IBIS stabilisation.
Testing...
For convenience, I took pictures of the TV screen at about 3m with both lens at F2.8. The dot pitch of the TV is about 0.8mm (I can make the pixels out with the naked eye at distances up to about 1.5 m. A few scanning artefacts are visible.
Here are the results, hand-held with IBIS on (all processed from RAW via Capture One, with no adjustments):
Above are the side-by-side photos from each lens (low res screen-print). At this resolution The FD (on the left) is noticeably warmer, has better contrast and is generally more appealing. My (non-photographer) wife confirmed this view, without hesitation.
Surprisingly, with all else being equal, the EF needed a shutter speed that was about 35% longer than the FD: 1/13s to 1/15s for the EF vs 1/20s for the FD - quite a large difference. Note that the EF had a (stuck) Kenko UV filter on it, whereas the FD was bare - but that shouldn't make 35% difference.
I zoomed in on the left eye to 100% magnification:
At this level of magnification, the TV's pixels are clearly visible in both pics ... BUT, the FD is clearly sharper. I took six or seven photos with each lens and these results were consistent.
Testing...
