beachbumdave
Active member
I'm not sure what anti shock is. Its on Menu - Gear E - anti shock
I hear there is less vibration so my pictures will be sharper if I use it. However when I use anti shock I can't use continuous shooting. The high speed and low speed continuous are greyed out until I turn off anti shock.
I guess I should use anti shock for one at a time shooting but is there a way to switch off anti shock and turn on continuous shooting with a function button? If the situation demands rapid shooting there isn't really time to go find Menu Gear K and then find the control to turn on rapid continuous shooting. If you want to switch to rapid shooting there should be a way to rapidly enable it.
