Recommend Compact Tripod?
Hi Olga,
How did you get such good price for the BR-5S? It's $49 at Outpost.com and $44 at B&H. Did you get a promotion? Did you buy at their actual store? Thanks.
Regards.
Mike.
I've been using a tripod that I found at Fry's for ~$20. (The BR-5S
model)
http://www.hakubausa.com/csite/c_products3.asp?cc=10&cs=120
It's not something I would trust in the wind of the outdoors, but
something that has served my limited needs. Light for packing or
carrying when traveling.
  • Olga
I see. Then the Ultrapod II might be the way to go. That's a very
sturdy tabletop tripod, and it has a velcro strap that allows you
to attach it to a post. Of course, it may be just a tad longer
than the dimensions you're looking for.
I had originally dismissed this model because I thought it would have the same camera adjustment limitations as a similar tripod I currently own (combination folding tripod/window mount). Can you position the camera vertically (sideways) with the Ultrapod II?
Funny, now that I think about it, I actually have the Slik mini. I
use it for my desktop camcorder/internet-cam. The reason it sits
on my desk is because I never found it practical enough to take on
the go. Even though it's a mini-pod, it really isn't that much
smaller than something like the Velbon 343e, and it certainly isn't
as practical. With a tripod like that, your really just paying for
a less compact version of the Canon mini-pod that you already have.
This is the Canon mini tripod that I have:
It's as portable as you can get (pocket size), but it's just not suitable for a larger camera, it's adjustment knob is too close to the camera for comfort, and the ball mount doesn't allow for sufficient range of motion, making it impossible to set up the camera for a vertical portrait shot.
I also have the Ultrapod I. That stays in my camera bag, and it
comes in handy once in a while. It's not as sturdy as I'd like it
to be, though. The Ultrapod II is improved in that regard. Yes, I
think you would be quite happy with the Ultrapod II.
Are they widely available in stores? I'd like to see one in person.
"Weak" in what sense?
Does it not lock down adequately when weight is applied to it, such as the G3 with a 420EX flash in portrait orientation?
If you can deal with the weak ballhead of the Ultrapod II, that's
the best bet. If you need the pan and tilt, a cheap multi-section
tripod (any brand will do) from a local store will do.
Ulysses
Thanks, that gives me a much better idea of how it works. Seems to
be a ball mount, which would provide total freedom of adjustment,
but not too much help if you wanted to pan the camera smoothly and
evenly, such as for photostitch panoramas.
Gotta be honest with ya here: If I'm serious about using the camera
for panos, I'm not going to be using ANY of the table-top tripods.
I'm going to use something more solid and more comfortable. A
full-size tripod and a nice basic but sturdy head like the Bogen
3030.
If I were serious about this, then yes, I'd agree. But if you traveled somewhere and you were not willing to lug around a full sized tripod, would you not even attempt a pano shot, or would you give it a go with a compact tripod?
Or is it virtually impossible to get acceptable results without a full sized tripod in this case?
The Pro comes with a compact ball head instead of the pan-head.
The Pro II has a two-way pan head with positioning handle. I think
the picture is inaccurate. This is what it ought to look like.
Yes, that's the Pro II. But the Pro I, with a ball head, is priced significantly higher (almost double). That's what I find confusing. I think the prices should be much closer, and I would expect that, if anything, the pan head would cost more than the ball head.
Primarily, I need maximum portability while still allowing me to
set up the camera on a table, trash can, wall, car hood, etc.,
without restricting camera positioning.
On those surfaces, you're just begging for instability and/or an
accident to happen. Just be ready for it. :-)
I know, and I try to be careful. But even with a full sized tripod I've seen people almost trip on them which could send your expensive camera crashing down to the ground from a considerable heght.
(I wonder if that suction
cup would allow positioning the tripod on a slanted windshield.
Then again, why would I want to do that?)
Exactly! :-)))
Secondly, I'd like something I could use as a chest brace.
Now that might be nice. Seems I saw something that could do it, but
can't recall the link.
The Slik can do that. Hell I've even done that with my little Canon pocket tripod. For slow shutter speeds, anything helps in the absence of a tripod.
And thirdly, I'd like the ability to lock the camera's position
along each axis, to allow for even panning or tilting.
I guess if I go by my own priorities, I should get a ball mount
Hmm... and here I thought you were leaning towards the pan head.
Wow. You're confusing the both of us here. :-)))
Well, I was leaning towards the pan head... until you suggested I consider my priorities... :-)
Since panning is much less important to me than portability, ease of adjustment, and suitability as a chest brace, I'm now thinking that the ball head, while less precise, might better suit my needs. That is, so long as it provides complete range of movement, including allowing positioning of the camera for portrait shots without having the camera topple over.
I found this article, hope it helps...
George
I have a full-sized tripod that I rarely use simply because it's
too large to take anywhere. I also have a tiny Canon pocket-sized
tripod that folds flat. It's proven useful at times, but it's too
small and unstable for larger and heavier cameras like the G3 if
you need to adjust the angle significantly.
Are there any good tripods out there that are more versatile and
sturdy, yet can still fold up to about the size of those very small
briefcase umbrellas?
Sorry, forgot to add the link
http://www.megapixel.net/cgi-bin/fs_loader.pl?p=http%3A//www.megapixel.net/html/articles/article-tip2.html
George
I guess I can't really answer that for you. All I know is that I'm accustomed to traveling with a full-size tripod in most instances. And this is not the type of use that I personally put a table-top tripod into. It wouldn't "feel" right for me. Stability, leveling, foot slippage, etc.
Maybe someone else here will have a different experience, more positive than mine in this regard.
Wow!! I hadn't noticed the price difference (always the last thing I look at... silly me... my wife HATES that about me...)
heght.
Heheh.. I've seen that, too. But I've never seen a good full-size tripod tip off of a car roof or slide off of a card table. :-))
You know what strikes me as gimmicky with the Slik? That suction cup thingee. I can almost imagine it even getting in the way at times.
"Mike, go for the pan head... NO, get the ball head... wait... the pan... hang on..." Hahahahahah...
Panning would be a bigger deal for me if I were taking panos and/or videos on the tripod.
As it is, I don't do much by way of panos... yet. And I always do video handheld. One day I'll get into panos since the G3 will probably be so good at it.
But for my use also, I have a ball head on both my monopod as well as for my tripod.
Ultimately, I'm going to end up with both types. I intend to sometime soon purchase a basic 3030 Bogen head off of ebay.
Ulysses
