yes but what puzzles me is i prefer the image on the right my a mile.. not by minuscule nit picking standards but by a mile..
i deliberately didnt check too deeply into which camera took which image so as not to cloud my perceptions.. should i be seeing this or are my perceptions skewed.. hence my comment about not being sure as regards what i should be seeing.. i did try and make allowance for the reflections in the left hand image which do make it even worse when compared to the right hand image..
i simply see one image as being far better than the other image.. if i am correct in what i see (i may not be) what is the discussion about..
do i trust my perceptive judgement.. not entirely but i hope in this case i am right in what i see.. if not i should start to worry..
trog
trog
Two shots by two different cameras using the same lens and settings; developed by the appropriate converter in each case; opened in FastStone Viewer as a side-by-side comparison.quite what i am supposed to be seeing i am not sure
SD9 shot is at left; therefore you preferred the Merrill.
Pedantry is not a felony.
Ted
