Silver Chain
Active member
- Messages
- 55
- Reaction score
- 2
Hello All,
I've been reading here about mounting on acid-free foam core and am quite interested for a few reasons--but my particular set of issues could use some seasoned input . . .
The reason I am interested is that I always print on matte art paper (Aurora Natural) and my images do not need or want glass. Plus, I always crop to non-standard sizes. Always. Which presents problems for every component I have to buy, especially since the cost needs to stay down. But I can't crop any other way. I depend too much on composition.
I am seeking an inexpensive way to produce images saleable in, say, a coffee shop, or displayable at a library or other nice-but-modest setting.
All this together makes me think that maybe foam core or art board or some such could be my answer, but I've read that an inkjet print will be more prone to humidity-related changes in size that may make some mounting methods not work.
I am open to displaying/selling either without a frame or in one; willing to consider a matte but would prefer to do without; but again, the budget is on the low side.
So first, what would be my best bet for a truly custom size of foam core? I found a good online place that willl cut custom, but only to the inch. That's not custom enough. Is there a way to cut neatly and accurately myself? Or will anyone cut even more custom?
Because, if I can get a truly custom size, then I guess I can mount to the edges if you can assure me that this won't wrinkle in the summer, or maybe use museum corners to float the image so I don't have to worry about the wrinkling [??], then cover the corners with a custom matte, and frame without glass. Oh, but then the FRAME needs to be a fully custom size. Hmmm.
I think what I am probably going to need is a method for custom cutting, or a source who will cut to the exact size, plus a method for affixing that will definitely work with matte inkjet output as the weather changes . . . yet that will not show . . .
Can anyone weigh in? I'm having trouble arriving at a solution that works for matte/no glass/very custom sized/low cost.Thank you very much.
