I've been reading the "FZ1000 and macro" thread
Who here has used the Panasonic Lumix DMC-FZ1000 10x High Definition 2 Element Close-Up (Macro) Lens (62mm)?
What is your experience? Quality?
How does it compare to other close-up lenses on the FZ1000?
http://www.amazon.com/Panasonic-DMC...-1&keywords=62mm+macro+lens+achromatic+fz1000
First, that's not a Panasonic product. It's just somebody's 10 diopter lens with a 62mm thread. It's unreviewed, and I suspect it's not particularly good.
Particularly as a first lens, you'd be far better off with a Canon 250D closeup lens or a Canon 500D closeup lens. Make sure they're labeled "by Canon" and not just "for Canon". eBay typically has a good collection of used ones.
The 500D will give you about a 30x45mm fov with the lens 500mm from the subject. If you're trying to compare to other systems, this would be "0.8x", where "1x" means a 24x36mm fov - the same as a 35mm film frame. That's not so very different from the unaided camera at 45mm focal length, except that the unaided camera will need to have the subject extremely close to the lens, while you can be back 500mm with the 500D.
The 250D will give you about a 15x22mm fov with the lens 250mm from the subject. If you're trying to compare to other systems, this would be "1.6x"
Pick your lens (500D vs 250D) based on your typical subject size.
You'll also need to pick up a 62-52mm or 62-58mm stepdown ring, depending on which diameter Canon lens you get. You'll be working almost exclusively at high zoom, so the 52mm will work fine.
If you get more than one lens, just get them the same diameter in case you want to stack them.
Sherm
http://www.flickr.com/photos/32989985@N07/sets/
