Hi.
I'm very inexperienced when it comes to flash photography but I think it's time I got experienced
I shoot medium format (gw690, rb67) and occasionally digital (5dII)
I have an older flash that I have used occasionally with the gw690. I'm now looking for something that has a variable output. I need more control.
I would like to be able to use the flash on my 5d and use TTL for very quick use. whilst also using it with my film cameras
I know older flashes can't be used on newer cameras without breaking them. Does this work both ways and will a newer flash work with the older systems? I can shoot via sync cable or wirelessly if needs be.
I'm also looking for a lightmeter that can measure the flash.
when shooting medium format I'm going to need some accuracy and don't really want to be setting my 5d, shooting a test, and then plugging things into my film systems just to take a shot accurately. so a lightmeter is going to be needed
so essentially - flash recommendation with TTL and variable power output, that will work with 5dII and rb67. and a light meter to help me measure without having to switch between digital and film!
Of course, i'm looking to spend as little money as possible!
