I want to be able to print 16x20s , 8x10s, 4x6s, and pocket size pictures matte paper and glossyWhat size portrait prints?
Brian A
Epson 3880, if you are in the US (you do not list a domain in your profile and I have no idea of prices in other regions).I want to be able to print 16x20s , 8x10s, 4x6s, and pocket size pictures matte paper and glossyWhat size portrait prints?
Brian A
That and light modifiers is all they do.Thanks, and I thought profoto did lights ?
I have never used them. They are regarded as second only to OEM inks. If I remember correctly, the vivid magenta wasn't up to OEM standards.I saw one of your posts helping someone figure out a 'cone' ink issue. What's the story on cone inks ?
Cone piezographic inks are highly regarded.
Brian A
They tend to settle more than any of the other pigments. They inks themselves are also more viscous than the other colors. This settling and increased viscosity has been the cause of clogging of the VM channels on printers such as the r2880 and the r3000.I have never used them. They are regarded as second only to OEM inks. If I remember correctly, the vivid magenta wasn't up to OEM standards.I saw one of your posts helping someone figure out a 'cone' ink issue. What's the story on cone inks ?
Brian A
No.Glossy paper is not the same as the kodak photo paper that someone would get from a pharmacy that develops photos from a kodak disposable camera is it?
Epsons clog on their own ink - is it worth the risk?Cone inks are resin encapsulated pigments just like OEM to produce gloss on Glossy/Luster/Satin papers to help with gloss differential. The other 3rd party good inks, Precision Colors, Inkjet Carts, Ink Republic inks are not encapsulated and the VM is not glossy and evident for so on the the 3 paper types mentioned above. If you only print on matte papers then all the mentioned 3rd part inks are fine. I find that Cone inks actually have more gloss than OEM which works great on high gloss papers to where you don't see any gloss differential at all.I have never used them. They are regarded as second only to OEM inks. If I remember correctly, the vivid magenta wasn't up to OEM standards.I saw one of your posts helping someone figure out a 'cone' ink issue. What's the story on cone inks ?
Brian A
The R3000 has a slight issue with Cone VM as the VM is the most viscous of all the inks and needs to have a manual clean more often than the other colors do. The R3000 doesn't have pressure feed carts as the the 3880 does, the pressure feed elminates the VM problem with the 3880.
I run OEM VM ink with the other Cone colors in my R3000 and haven't had to run a manual print head clean in over a year.
Bob P.
Really?Epsons clog on their own ink - is it worth the risk?Cone inks are resin encapsulated pigments just like OEM to produce gloss on Glossy/Luster/Satin papers to help with gloss differential. The other 3rd party good inks, Precision Colors, Inkjet Carts, Ink Republic inks are not encapsulated and the VM is not glossy and evident for so on the the 3 paper types mentioned above. If you only print on matte papers then all the mentioned 3rd part inks are fine. I find that Cone inks actually have more gloss than OEM which works great on high gloss papers to where you don't see any gloss differential at all.I have never used them. They are regarded as second only to OEM inks. If I remember correctly, the vivid magenta wasn't up to OEM standards.I saw one of your posts helping someone figure out a 'cone' ink issue. What's the story on cone inks ?
Brian A
Bob P.
Brian A
Bob P.
I have two PRO 3800s and one R 2880 both on OEM Epson inks and I don't even know what a clog is! In fact none of my 16 printers seem to ever clog! I wonder why?
Joe
Brian A
Bob P.
Joe
Brian A
Bob P.
Joe
