thank you very much for your explanations. I recently bought a Nissin i40, which is optimal for traveling due to its small size. Unfortunately it has non built in exposure control. Therefore I am searching now for an table or a smartphone app to calculate the manual settings.
The Nissin i40 is a good flash and works well on the camera. If you have the "FourThirds" version it will work in TTL mode on your camera without any problems.
I have not understood yet, why the automatic flash control depends from the difference between G5 and G6. My Panasonic G5 can be operated in TTL mode, if the Nissin i40 is connected via the hotshoe.
I don't know why Panasonic didn't include the flash RC (remote Control) functionality in their cameras prior to the G6, but they didn't. It may have been a licencing issue or software incompatibility.
This RC functionality allows you to control up to 3 groups of remote flashes from the camera. You can set the flash mode and power level (TTL/Manual/Auto (if supported by the flash)) as well as switching between normal and FP/HSS mode.
If there would come a radio flash trigger to the market, which would transfer the TTL data to the flash, G5+i40 should flash automatically - or do I miss some information.
Here is how the Olympus TTL flash system works. A pre-flash is fired. The camera measures the this exposure and calculates the necessary power of the flash needed for proper exposure. It then takes a picture using the calculated flash power. There are a couple of downsides to this. Firstly the pre-flash can cause subjects to blink so you get photos of faces with closed eyes. Secondly it slows down sequential shooting.
If the flash is remote from the camera the camera needs to communicate with it to:- set the power of the pre flash; trigger the pre flash; set the power of the main flash; trigger the main flash at the correct moment. This is what the RC functions does. Olympus it uses a rapid series of flash pulses to do this.
All a simple radio trigger can do is to send a signal to fire the flash. It can't send the TTL data.
The Cactus V6 is a sophisticated radio trigger that can send TTL data. Currently the support for Olympus flashes is at a beta (pre-release) stage. If it works as well as it does for the Canon flash system you may get what you need. Recent discussion thread about it
here .
Alternatively you could buy a flash extension cord to physically link the remote flash to the camera. They are cheap and easily available on eBay. Using a short cord you can hold the flash in your left hand and the camera in your right and take pictures like
these by Robin Wong. He used the wireless RC function but a flash cord would have worked just as well. It is worth noting that Canon flash extension cords are often cheaper than Olympus ones and work just as well due to positioning of their contacts.
Don't be too discouraged about the lack of remote TTL. Most remote flash users use manual flash control to set their flash power levels, as the camera can't read the photographers mind about the lighting effect desired. In consequence remote TTL metered exposures often produce sub-optimal results.
I use the RC function to manually set the remote flashes power from the camera as it saves me from physically going to them. However this is just a convenience. I would get the same exposures if I went to the flashes and set the power levels there.
Interestingly there is a petition of photographers on this issue (search with google for "petition ttl mft").
Regards
Claus
Peter
'Keep taking the photos'
