Hey nx users, I've tried some website for how many shots my nx2000 has taken, but i couldn't find any nx system supported website. Do you know where can i look for it?
I did a search for 'shutter count' and ten months ago there was a post in the Sony forum that contained this sentence;I don't think it does, at least last I heard the shuttercount isn't being written to the exif data on the more recent NX cameras.Doesn't the following from a command line work? exiftool -shuttercount yourimage.jpg . Or photome software. More of a question than an answer since I don't know myself.Hey nx users, I've tried some website for how many shots my nx2000 has taken, but i couldn't find any nx system supported website. Do you know where can i look for it?
https://www.flickr.com/photos/122298536@N06/
Wow. Looks promising.I recently by accident discovered a way to get log files dumped to the memory card: Press and hold home button and press in the top dial until the green focus light comes on. Now on the root of the card you have some log files. Mine looked like this:
20141007_134827_dlog.inf
20141007_134827_log.inf
If you open the one with "dlog" in its name and search for "shut" you can see this line:
SHUTTER RELEASE COUNT : 2488
I'm not sure if that's the total shutter count or the current file count - that's for someone else to discover, but it's an option.
Edit: Well, it's about 50 shots more than the most recent image taken so that could account for some factory testing shots. So this seems to be a legit way to find out.
Sorry, could you better describe which button this is. On the NX300 the menu button goes home... but if you're already at home it goes to the menu, is this the button you mean?I recently by accident discovered a way to get log files dumped to the memory card: Press and hold home button
... You shouldn't be able to press in the dial should you? It's only supposed to turn.and press in the top dial
?until the green focus light comes on.
Are generating a lot file by causing a camera malfunction by pressing in a dial too far that's not supposed to be pressed in?Now on the root of the card you have some log files.
Indeed - since the top question was about a NX2000 my reply was as well.His camera is the nx2000 which apparently has both a home button and a top dial that can be pressed.
