Leo
I am trying to select a wide lens from three focal lenses: 7.5mm, 8mm and 12mm.
The 12mm is not that dramatically wide as 7.5mm and 8mm which are true fisheye lenses.
There are several latest posts related to the subject, however the mien benefit of reading then was sample photos taken with 7.5mm and 12mm.
The subject complicated that these lenses are marketed under three different names: Rokinon, Samyang and Bower. It seems that the lenses may differ as they priced differently. The listed manufacturers are offering the same focal lenses under their own brands.
I have used a 7-14mm Panasonic lens on a GX1 with excellent results. However, using a graduated filter was not easy. The distortions at 7mm were small and easily corrected. The view angle was around 120deg not 180deg.
1) I can not decide on 12mm vs 7.5/8.mm.
2) Which one of these three Rokinon, Samyang and Bower is the OEM is not clear. Also, the OEM version may not be the best.
3) Is a lens version with a hood removing option should be preferred?
The lens itch came from an Adorama unexpected $50 credit to be applied to the next purchase
Thank you for opinions and ideas.
Leo
PS My thank to all for the help in the firmware update of my week old OMD
Leo
