Ahoy!What do I gain from the new Tamron or either the new Sony 70-200mm or the older model in terms of focusing speed and accuracy compared to my current Tamron SP 70-200 F/2.8 Di?
I shoot with an A77 & A900.
I'm mainly interested in faster focusing. IQ wise I'm happy with my current Tamron.Ahoy!What do I gain from the new Tamron or either the new Sony 70-200mm or the older model in terms of focusing speed and accuracy compared to my current Tamron SP 70-200 F/2.8 Di?
Well, if you've checked the specs and prices, you'll answer your own question. You've left out the Sigma AF 70-200/2.8 OS EX DG APO HSM. The standard Tamron 70-200/2.8 Di has great sharpness and colours but is physically slower and can hunt to acquire focus lock in less than decent light so many opted for the standard Sigma 70-200/2.8 back in the day. Then you have the Minolta AF 80-200/2.8 APO G/APO HS G which are both superb though the Sony/Minolta 70-200/2.8 G's are way overpriced for the extra 10mm.
I don't see the need to waste money just for the sake of a simple replacement unless there's something you absolutely must have, though depending on budget if you must get one, I would go with the Minolta AF 80-200/2.8 APO G/APO HS G, Sigma AF 70-200/2.8 OS EX DG APO and also look at the Tokina AF 80-200/2.8 AT-X PRO.
Mark (aka Pirate!)
Ahoy!I'm mainly interested in faster focusing. IQ wise I'm happy with my current Tamron.
If you think it's 'heavy' then try carting a 300/2.8 around. That's a heavy lens and I would think the Tamron is about half the weight or less so easily hand-holdable in comparison.It is very heavy so I use it on a monopod.
Not quite. 5.1 lbs vs 3.2 lbs. I'm not saying it's not hand hold-able but when shooting basketball with my A77ii I have to keep the camera to my eye for long periods at a time so using a monopod certainly is helpful.If you think it's 'heavy' then try carting a 300/2.8 around. That's a heavy lens and I would think the Tamron is about half the weight or less so easily hand-holdable in comparison.It is very heavy so I use it on a monopod.
The Tamron 70-200 f2.8 USD weighs 3.1 lbs while the Sony 70-200 f2.8 G weighs 2.87 lbs. The Sony 70-400 Gii weighs 3.31 lbs. I got these weights from the B&H website. The older Tamron 70-200 f2.8 Di weighs 2.53 lbs so is that the lens you are talking about?I've been very happy with the new Tamron. It's my first 70-200. I looked at the Sony, but the price wasn't as big a deal to me as the weight. I wanted my 70-200 to not only be sharp at f2.8 and fast focussing, but also be light and small enough to fit in my travel bag. The Sony 70-200 is the same size and weight as my 70-400, but the Tamron is significantly lighter.
Depending on your needs the 80-200 HS that KEH has is an excellent lens and mates up with the A77 very nicely. It has reasonably fast AF and does not seem to hunt very much. I will be testing my copy with the A99 tonight once the A99 arrives. The only drawbacks I have with the 80-200 are: No weather sealing, Loudish AF (screw drive), no focus limiter, & front element rotates with AF (effects CPL).I talked to my local camera store yesterday, they told me the new tamron is very close to the sony 70-200 v1.
I could get a used sony in the $1500 range or the tamron which comes with a six year warranty. KEH does have a minolta 80-200 but it's in EX condition (80-89%).
Ahoy!The Tamron 70-200 f2.8 USD weighs 3.1 lbs while the Sony 70-200 f2.8 G weighs 2.87 lbs. The Sony 70-400 Gii weighs 3.31 lbs. I got these weights from the B&H website. The older Tamron 70-200 f2.8 Di weighs 2.53 lbs so is that the lens you are talking about?
