I am surprised that you got good results with the D200 but not with the D300, since they work the same way ... You are complaining about autofocus in low light. Don't answer me, check the manual for focus assist built into the camera and also built into your Nikon flash. Also, review your images to see where the camera has focused, wether or not it will take an out of focus image, etc.
I tried using the same specs I used with the 200 1/60 and adjusted the flash power is all. With a Tamron lens no doubt. I can't even get decent rsults with a Nikon lens!I am surprised that you got good results with the D200 but not with the D300, since they work the same way ... You are complaining about autofocus in low light. Don't answer me, check the manual for focus assist built into the camera and also built into your Nikon flash. Also, review your images to see where the camera has focused, wether or not it will take an out of focus image, etc.
It's all in the manual! Experiment! Have fun! Once the equipment is paid for, it's all free!
JC
Some cameras, some lenses, some computers
You seem to have a great deal of difficulty using your camera. Something or someone is broken.
SmM I use the built in, never wanted to spend the $$$ on a Speedlight. You guys have a lot more experience with this body that I do, if there are settings I need to look at Im all ears....Hi Joe
Out of interest, are you using the built-in flash or Nikon Speedlight? You should definitely not have issues with focus in poor light. Certainly should get better lock than using the D200 which in my years with it used to struggle with anything but the centre Af point.
However, if you are using a Speedlight and the Speedlight's red AF-assist beam, then I might have news for you. There seems to be a well documented issue with front-focusing on certain lenses with the more recent cameras. I only found this out after coming home to many misfocused photos when I had used my SB-800 for fill flash, in good light. With my D700, the problem occurs with Sigma 24-70. Couldn't reproduce the issue with D2h. Focusing is fine if I turn off the flash's AF assist.
In very low light, the camera will have trouble focusing, because there is nothing with enough contrats to latch on.SmM I use the built in, never wanted to spend the $$$ on a Speedlight. You guys have a lot more experience with this body that I do, if there are settings I need to look at Im all ears....Hi Joe
Also you have to use the center focus point as I recall for this assist to work. I'm not sure what is going on but all those pictures are OOF and/or have motion blur etc.In very low light, the camera will have trouble focusing, because there is nothing with enough contrats to latch on.SmM I use the built in, never wanted to spend the $$$ on a Speedlight. You guys have a lot more experience with this body that I do, if there are settings I need to look at Im all ears....Hi Joe
A Speedlight has a built-in light that illuminates the target area in red, thus assisting the AF system. You do not have a Speedlight, but then there is the built-in camera light, between the shutter button and the flash. Set a9 to ON, and use S mode. The assist light should come on when you press the shutter or AF-ON.
I don't thin you have a focus issue as much as you have a shutter speed issue. Since you do have some ambient light, you have motion blur from the 1/60 shutter speedAs some of you may know I finally upgraded (?) from a D200 to a 300s, and so far flash photography with the D200 is Far superior....just getting the 300s to focus is turning into a major chore!
Couple more questions, since the Flash sync with the D300s is 1/250, why would you want to use other shutter speeds other than 1/250 while using the flash? Also what ISO do you shoot doing Flash photography?In very low light, the camera will have trouble focusing, because there is nothing with enough contrats to latch on.SmM I use the built in, never wanted to spend the $$$ on a Speedlight. You guys have a lot more experience with this body that I do, if there are settings I need to look at Im all ears....Hi Joe
That is all described on page 268 of the manual. There are restrictions on certain lenses: those are listed on page 345 of the manual.
JC
