photoKinetic
Leading Member
Greetings,
I enjoy the additional grip offered by an ever-ready case. Generally, I use the bottom half only when out and about and use the top half for secure travel. As most of you know, the zr700/800 series does not have a VF and the LCD can be hard to see in bright light. Problem solved - get a Clearvewer.
My Problem: The additional thickness of the bottom lip of the case concerned me that I would have to hack and possibly ruin a fine product like the Clearviewer. Additionally, I liked the suggestion of another forum member who inquired about a viewer that might fold under the camera (serving as a stand) while also allowing for optional use of the LCD without removing the viewer.
Disclaimer: this is NOT a Clearviewer. It is my custom adaptation of a magnifier (intended for another use). It has a 5X, 30mm (1 inch) glass lens. The end result is not quite as compact as the above because of the case issue but it serves my unique need.
This experiment might serve as inspiration for a commercially made viewer for other's who have a similar need. Maybe no one cares, just thought I would share.
vK
folded against LCD
open
bottom stand
vK
folded against LCD
open
bottom stand
