Ok, sorry I got you wrong.This is a good example of how confusing these posts can get. It really can be a lousy way to communicate!
All the best, Matti Remonen
You are wrong. Your's may not; mine does. I just switched my genuine Nikon MB-D12 back and forth at least a half dozen times between the 810 and 800e. There is no discernable difference. I spent a few minutes looking at the bottom of the grip and the bottom of the camera. There is no way that there is a watertight seal between the grip and body at the edges of the grip. For it to be watertight you would need a gasket / seal and there is neither one.I did test it again today. I did put the original Nikon battery grip to a d810 of a friend, my d810 and a d800 of his assistant. The two d810 presents the same gap and not a perfect fit all over while the d800 has a perfect fit to the grip and it looks like it's one body.
Also, the molding of the d810 base it's different from the d800.
I am the one who spoke with the nikon operator but they first act surprised when they tested it themselves (I've heard a "oooooohhhhhh" of the supervisor engineer while he was chatting with the operator and they were testing the battery grip on the d810) But then they said they were aware of it. So I guess there is a bit of confusion on the issue.
I can't speculate if the camera is sealed or not, but one thing is sure: THE d800 handgrip does NOT fit the d810.
And you would be hard pressed to find anyone this side of OCD that is as fussy about this type of thing as me. And I see absolutely nothing in the fit of the MB-D12 on my D810 that causes the least concern.There is also another possibility, but that would be an horribilous scenario, like A good bunch of d810 have a faulty base with different molding. Hopefully not.
This is not true, see below.The two d810 presents the same gap and not a perfect fit all over while the d800 has a perfect fit to the grip and it looks like it's one body.
Yes, this is correct. Or at least it looks like it is different, the bottom right cornes is modeled differently.Also, the molding of the d810 base it's different from the d800.
Here's something I dug out from web:I can't speculate if the camera is sealed or not, but one thing is sure: THE d800 handgrip does NOT fit the d810.
Or your grip is a counterfeit unit.There is also another possibility, but that would be an horribilous scenario, like A good bunch of d810 have a faulty base with different molding. Hopefully not.
Ok, it's not exact fit. Neither is D800. And NOT being millionaire I'm extremely happy that the grip fits D810 mechanically, if not aesthetically, on par with D800. And it also work as designed. Therefore (not being millionaire) I'm very happy that I do not need to spend another $500 (it would be like €400 in Finland) for a grip. Just for aesthetical reasons. For me this is for taking photos, not as a showcase.I am sorry but when you pay 400$ for an hand grip you want it to be perfect not adaptive, unless everyone here is a millionaire and don't care.
If you go on NikonUSA website and go to MB-D12 and go to the "Compatible with" It has three cameras listed. D800, D800e, D810. Neither the D800 or D800e says "designed for" with the D810 listed only as "compatible with"Nikon confirmed that the MB-D12 is not the handgrip for the d810 as it was designed for the d800, but it is compatible with the d810.
To me, as a professional, it bothers me that Nikon does not have a specific hand grip for the d810.
It makes me feel as the d810 is a prosumer camera.
It might be a psychological factor but it's like seeing a hot girl who has a detail that bothers you very much. It does not feels complete. It bothers me so much that I might buy a clone and experiment by building a top molding around the d810 with a 3d printer in my spare time.
I have written to Nikon and they said MB-D12 is compatible with D810 and requested me to bring it down to the service center so that they can explain to me....what cow sense is that.....Nikon confirmed that the MB-D12 is not the handgrip for the d810 as it was designed for the d800, but it is compatible with the d810.
Maybe he can use his 3d printer to print a girlfriend.You either have a bad case of OCD or too much time on your hands. Or a fake MB-D12. And good luck with finding a girl ( hot or not ) that doesn't have one "detail" that bothers you. Vice versa, and I haven't heard of too many women stuck on just one "detail" when looking for a man.It might be a psychological factor but it's like seeing a hot girl who has a detail that bothers you very much. It does not feels complete. It bothers me so much that I might buy a clone and experiment by building a top molding around the d810 with a 3d printer in my spare time.
First one needs to know what a girlfriend is to be able to design one. :-DMaybe he can use his 3d printer to print a girlfriend.
There have been 3 pages of debate on this issue. If you strongly believe this is a defect, it can be useful to compare serial numbers. Maybe there is a "production lot" of grips which changed shape slightly or were molded incorrectly?You can actually look from the back to the front.
It simply look horrible, not pro… Nikon, shame on you!
The bottom of the base of the D810 is exactly the same as the D800, the only difference is in the depth of the base plate therefore the MB-D12 fits exactly the same on both of them.Hello all,
As much as very similar, the d800 and the d810 bodies differs a bit in shape and dimension.
I have tested my new d810 with a battery grip made for the d800 and it doesn't properly fit.
I am quite surprised that Nikon made the d810 compatible with the MB-D12 which is not.
I mean, it does work but it doesn't fit and so it makes it useless to have a weather sealed camera.
Am I the only one who noticed this?
Thank you for your time.
M
