Great lens
Wojtek Rychlik
New member
Cascade, CO, US
This is a compact 10x zoom lens designed for cameras with Micro Four Thirds sensors. It has been tested with Panasonic Lumix DMC-GM1 camera set on maximum resolution of 4592 x 3448 pixels and RAW quality. The sharpness is best at f/5.6, and at the f/8 is wery similar.
I've tested this lens on 6 focal lenghts, 14, 26, 46, 73, 97, and 140 mm. Multiply these by two to get equivalent of a full frame sensor (24 x 36 mm). To see the charts in full magnification please click on the thumbnails on this page: http://pikespeakphoto.com/tests/panasonic-lens14-140.htm. Dependence of the image quality in various parts of the four thirds sensor is shown, with the average resolution in hundreds of line widths per picture height (LW/PH; normalized to 3x2 image size ratio, 4592 x 3064 pixels), given below each chart.
The image quality is excellent in most of the settings. Note that resolution "30" is theoretical maximum for the sensor of this pixel count. The resolution drop at small apertures is to be expected due to laws of physics.
Distortions are minimal, which is exceptional for these type of high zoom lenses. The size of the circles are constant throughout the entire sensor no matter at what focal length. Chromatic aberrations are more pronounced at wide angle settings and they are small at 46mm and larger focal lengths.
The closest lens that I've tested that resembles this lens is Tamron Zoom Lens AF 18-270mm, however that is lens designed for APS-C sensors (22.3 x 14.9 mm) and not for micro four thirds (17.3 x 13 mm). It's hard to tell what is the maximum sharpnes at f/5.6 as the sensor has not enough pixels and maximum theoretical resolution was achieved in many settings, but it seems that it is much sharper than the Tamron lens as only slightly higher resolution was achieved on the 4x larger sensor. Lumix G Vario lens beats it hands down when distortions are taken into account. Another factor that distinguishes those two lenses is the speed. While the Tamron lens is sluggish, sometimes rendering autofocus function useless, especially in low light or low contrast subjects (tested with EOS M body), the Panasonic lens is very responsive with Lumix DMC-GM1 body. Only this feature alone is so important it could be a decisive factor in purchasing plans.
The optical quality of this lens is extraordinary, and it is also very compact 10x zoom lens, making it the lens of choice for travellers who don't want to carry heavy full frame cameras but who want to take high quality photos.
My experience is similar. Geat optics, finally a no-compramise superzoom. Great for macro too (w/Raynox).
My experience has been the same. A very fine lens for the price.
How did it handle on the GM1? I was worried it would be too large/heavy.
I just got this lens and to be honest am slightly disappointed. I took it outdoors to compare it to my Panasonic 14-45mm (original version) on my E-M5 and found the 14-140's images noticeably softer at most apertures and focal lengths. It seems to have a sweet spot around f/6.3 where it more or less matches the 14-45's crispness, but go much above or below that and things start to get blurry. There's also noticeably more chromatic aberration, though nothing that Lightroom can't clean up.
I uploaded a few example crops to demonstrate the difference: http://www.dpreview.com/galleries/355605034/albums/panasonic-14-140-and-14-45-comparison
It's not to the point where I'd call it bad, but I bought the lens hoping I could leave the 14-45 at home and now I'm not so sure.
Don't worry, indeed most of panny's zooms are more or less in similar size and weight.
14-140 MII 75mm 265g
45-150 73mm 200g
45-175 90mm 210g
7-14 83mm 300g
12-35 74mm 305g
35-100 100mm 360g
45-200 100mm 380g
Indeed the added weight might help keeping handheld steadier.
Does anyone of you have noticed that when you start video recording image starts to vibrate and jitter a little but noticeably and it is disturbing in a big screen.
Like this:
