R
Raist3d
Guest
[No message]
Thanks. That also shows the resolution differences.A link to my color resolution comparison (Just in case you missed that thread)Anyway, just thinking out loud. Would be interesting to see what happens with colors like red on purple, etc.
color resolution
Huh? Strange, why don't they have 6.0.4? Lazy to update?I tried a few things but effectively yes, the issue does show up. This is SPP 6.0.3. This is the current version of Sigma SPP available at the Sigma website for download (at least from USA links), as of July 24, 2014.
It looks very much like the example I had from that label. Would be interesting to experiemnt with.Here is a screen grab. Notice I put the noise reduction all the way down. If there is a setting I am missing please point it out. Thanks!
PrebenR- I think something interesting to noice- notice the kind of blue that is against the yellow. Seems like a cyan blue, closer to the top layer response than the blue you had. Maybe that's what makes it more problematic.
But that is a border as I say.Not necessarily- you can get this at any point of color transitions that are abrupt within for example cloth threads.The problem though is that you would get this effect at the border only.The Merrill won't have this (as you see it). Preben was saying they are using an older version of SPP, certainly newer SPP could deal with this better. But as I said many times, it is a FACT, not a guess, that the Quattro has less chroma resolution- even an exFoveon engineer confirmed this.
Not my shots.Other tones can be faked/interpolated and they would look close but not like an X3 capture.
Not sure if you are talking about now of your shot or the "beer garden" shot.If it is purly chroma and not some processing issue. Then you are talking about 2 pixels. So for this to happen in the banners (both of them show this), then in my mind it is down to processing.
So you want the 4 measurements of the top layer to be combined? How does it make it more acute? Not sure I follow, but I can test it.No. That's not what I said. What I said is if I want a true X3 capture with full color acuity on the Quattro, I would just shoot at 4.9MP.But do you then say that any 20Mp Bayer camera is in effect a 5Mp camera? As it doesn't have more blue or red photosites?I think this would bother me more on the Quattro if there wasn't any true X3 capture mode, but there is. I would be happy shooting at 4.9MP and using the higher resolution for B&W.
Whatever, I'm fed up discussing the Bayer notion that is stuck in peoples head.According to the docs it's one big. Keep in mind, I am not talking about Bayer, I am talking about Quattro vs previous Foveon. Basically if one unique characteristic of Foveon is not quite there and it looks more towards an AAless Bayer in some ways, some uniqueness of it is lost.
I think we need to see a plurality of shots but the other link sure shows the color resolution loss (the wheels).
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
The blue looks different time. Also to experiment: cyan blue and low intensity. That may confuse the algorithm more.Huh? Strange, why don't they have 6.0.4? Lazy to update?I tried a few things but effectively yes, the issue does show up. This is SPP 6.0.3. This is the current version of Sigma SPP available at the Sigma website for download (at least from USA links), as of July 24, 2014.
Why? There rest of the areas look pretty sharpI still think there is some NR/interpretation when the SPP processes the file, but hard to say.
Will do.The blue looks different time. Also to experiment: cyan blue and low intensity. That may confuse the algorithm more.
No, I meant the algorithm that is used to develop the Quattro RAWs. Not what one sets in SPP.Why? There rest of the areas look pretty sharpI still think there is some NR/interpretation when the SPP processes the file, but hard to say.
No it doesn't always happen. I have managed to get the issue, but I have not tried your samples. I'll do much more experiments on this and then I'll post my findings.In "Flat View" you can see two test images I posted, just above this post. Someone with a DP2 Quattro please shoot a photo of each of those test images, and post it (no noise reduction please!), so we can see if this phenomenon always happens with yellow on blue.
That's not what I said. I mentioned what can be tricky situations or I think should be. I did not say you should stop testing (but stop if you want, I mean, by all means).OK if you know the answer, then I don't need to test this further?
The problem goes beyond the 2x2.
Relax, I'm going to do a lot of tests. But I'll wait until I finish to discuss it further.That's not what I said. I mentioned what can be tricky situations or I think should be. I did not say you should stop testing (but stop if you want, I mean, by all means).OK if you know the answer, then I don't need to test this further?
Sounds like the issue (as the other post shows) may perhaps have to do with transitions of blue and colors requiring from the layers below. It's interesting.
Relax, I'm going to do a lot of tests. But I'll wait until I finish to discuss it further.That's not what I said. I mentioned what can be tricky situations or I think should be. I did not say you should stop testing (but stop if you want, I mean, by all means).OK if you know the answer, then I don't need to test this further?![]()
interesting. thanks for posting.Very interesting. One shot nominal, the other same frame and all but with a yellow filter.
http://ichigo-up.com/Sn4/download/1405776566.X3F
http://ichigo-up.com/Sn4/download/1405772202.X3F
Looks like those "beer gardeners" have been busyConverted by me below, SPP 6.0.4
It's interesting the resolution for the Yellow sign comes back with a Yellow filter on top of the lens, but now there's a bit of color moire on the top fence of the building. Haven't looked at all the pic carefully to check for other artifacts.
First Foveon with color moire apparently
A few predicted this could happen, but the color moire will sure be of a different characteristic than classic AAless Bayer- and it is. Alternates with Yellow and Luma.
I don't think this would be an issue for a landscape (unless it has a fence and you are using a color filter). Fashion with weird textiles? Good question. Probably pretty rare too.
I can only think the original shot with that particular blue at that particular intensity makes it hard to discern high resolution red/green-> yellow.
