Yes. But it's an old rumor and the two lenses in question has been available for years. You just need a MMF-3 and an E-M1 to use them: Olympus 35-100mm f/2 and Olympus 150mm f/2.I know 35-100 is really good, but am wondering if there is future plan from m4/3 manufacture to make tele lens (>100mm) faster than f2.8??
Any rumor?
Any rumor?
18 is 28 equivalent on APS-C, where 17 is 35 equivalent on m43. 'Normal' zooms that only go as wide as 35 equivalent stopped being marketable in the late 80s.Why no 17-35, a la the Sigma 18-35? Would it be prohibitively large on a u43 body?
Any rumor?
Wrong. The equivalent to m43 35-100mm f/2 would be FF 70-200mm f/4 lens. The new Fujinon 50-140mm f/2.8 would be a close APS-C equivalent. They aren't small, but neither they are gigantic.That's quite impractical for Micro Four Thirds. The original Four Thirds DSLR system had an Olympus 35-100mm f/2.0, and it's pretty much the same size as those gigantic 70-200mm f/2.8 lenses for full frame DSLRs.
Please go back and read the original post and then reread the post that you have called "wrong." Ido S was making a SIZE comparison, not an equivalency comparison. The OP was asking about telezoom's faster than 2.8. Ido S responded directly to that. He said the Oly 4/3 fast tele zoom was huge like the fast FF 70-200 2.8's so it was not likely that there would be an m4/3 tele zoom faster than 2.8. Check it out in the database, IF you do so, you will see that, the Oly 4/3 35-100 is actually heavier, wider and longer than the Canon 70-200 2.8. I think you owe Ido S an apology.Wrong. The equivalent to m43 35-100mm f/2 would be FF 70-200mm f/4 lens. The new Fujinon 50-140mm f/2.8 would be a close APS-C equivalent. They aren't small, but neither they are gigantic.That's quite impractical for Micro Four Thirds. The original Four Thirds DSLR system had an Olympus 35-100mm f/2.0, and it's pretty much the same size as those gigantic 70-200mm f/2.8 lenses for full frame DSLRs.
Likely VERY limited market: Huge and expensive.Why no f/1.8 zooms at all, though? Why no 17-35, a la the Sigma 18-35? Would it be prohibitively large on a u43 body?
RaymondR
Did you even read what you replied to?Wrong. The equivalent to m43 35-100mm f/2 would be FF 70-200mm f/4 lens. The new Fujinon 50-140mm f/2.8 would be a close APS-C equivalent. They aren't small, but neither they are gigantic.That's quite impractical for Micro Four Thirds. The original Four Thirds DSLR system had an Olympus 35-100mm f/2.0, and it's pretty much the same size as those gigantic 70-200mm f/2.8 lenses for full frame DSLRs.
I repeat it again, the comparison is wrong and thus the conclusions.Please go back and read the original post and then reread the post that you have called "wrong." Ido S was making a SIZE comparison, not an equivalency comparison.Wrong. The equivalent to m43 35-100mm f/2 would be FF 70-200mm f/4 lens. The new Fujinon 50-140mm f/2.8 would be a close APS-C equivalent. They aren't small, but neither they are gigantic.That's quite impractical for Micro Four Thirds. The original Four Thirds DSLR system had an Olympus 35-100mm f/2.0, and it's pretty much the same size as those gigantic 70-200mm f/2.8 lenses for full frame DSLRs.
Any rumor?
