Tiwiliger80
New member
- Messages
- 5
- Reaction score
- 0
If this is common knowledge, I apologise for wasting everyone's time....and if I am wrong completely...well then once again I apologise....this is something I just noticed and thought to share with others if they have no knowledge of it as I didn't.
Set your camera in any of the movie modes where exposure compensation is available (best example to try is movie/s) and set your shutter speed and iso so that they are static (e.g. SS 100 and ISO 3200). Assuming you are in a dark environment, your aperture should be wide open, your shutter speed is set as is your iso so exposure compensation should have no effect which it does not........until you pass EV+2 where for the next 3 stops to EV+3 the exposure does in fact change which I can only assume is the sensor changing to iso 6400, 12800 and 25600 which is the sensor limit.
I assume this is the low light mode mentioned only once in the camera manual if you take video with any of the night scene guides active but having more control over the exposure variables in the other movie modes makes it a more viable option. The image is a noisy mess at those settings but for any situation where any image would be better than darkness, it could be handy.
