WhateverNickname
[No message]
Craig, Thanks for the explanation. It helps a lot. I shoot mostly in the Northeast - New England - and our brightest summer sunlight is no match for Arizona! Plus, we get plenty of overcast days all year long, but especially in winter.All of those examples were just taken from normal shots with the lens, and all save maybe one were 'unpredictable'. Not so much unpredictable (once you know it can happen), but more like 'not noticed in the field'. I shoot a lot in Arizona sunlight, which is so bright that you often cannot see much in the LCD besides a histogram. Yes, a lot of this can be seen when you take the image, but you do have to look for it, and that slows you down.Hi Craig. Looked at the photos and have a question. Is the flare due to some particular angle from which the images are shot, or is it unpredictable? Which gets to my REAL question - have you figured out how to avoid flare?
I use a tripod most of the time, so ought to be able to make adjustments for the lighting. This is a great tip to remember.How to avoid it? Simply be sure the lens glass is shaded. In order to do that, you almost have to be using the lens on a tripod so you can look at the front of the lens and do some sort of shading of it.
Recently I read a book about lighting, and this comes to mind reading your description. The "danger zone" you describe sounds like the place from which the light hits the lens wrong. And there are more "wrong" places to hit the lens with the 14-24 because of its bulbous shape. This might not be an entirely accurate description of what is happening, but it helps me visualize!But in my experience, most very wide angle lenses very often have the sun just outside the frame, in the 'danger zone'. Unless you specifically want the sun in the frame.
Anyway, bottom line is that if you really need to have an image with no flare, and the sun is in the 'danger area', you need to make sure all of the glass is in the shadow of the lens hood or some external object.
Gorgeous pictures, congrats!Thanks everyone for your thoughtful responses.
I have been doing solely wildlife photography for the last 2 years but a few months ago I bought a Nikon 12-24mm F4 and began doing landscapes. Here is some of my stuff so far: https://www.flickr.com/photos/rudypohl/sets/72157644844338092/
Being careful with my technique, and being a self-confessed pixel-peeping fanatic, and hoping to make large format prints of some of my keepers, I am wondering whether going whole hog on a 14-24mm F2.8 is the route I should go for edge-to-edge sharpness. Or whether should simply do my best with the 12-24/F4.
Thanks again,
Rudy
I know mate. I know every mm wider, means more change. Still I did a lot of research. If i remember correctly 24mm is just below 90°, 18mm is almost 100°, 16mm 106° and 14mm 114°. I used this numbers as guidelines when I was walking in cities, forest, others, to calculate 'would this be wide enough or not?' And answer was often yes, but quite a lot of situations it was not wide enough. Would 18mm have been good upgrade? yes. But as a huge fan of landscape (so it's sort of my specialty - after lots of thinking), i think 600 euro for a tad bit wider was gonna dissapoint me in the end. I took quite some 14mm shots today, and some of them Just had the subject in the frame with barely space left to catch it (like big churges from closeby for instance). It gives a lot of freedom in composition going from extreme wide (14mm) to normal wide (24mm). My first impressions is that I made the right choice, and that 14mm over 16/18mm has enough value to justify it.Congratulations. I just have one comment - 18mm is vastly wider than 24, so I wouldn't discount owning an 18-35 if I already had a 24-xx lens.
How did you pack/carry it overseas?
I find myself unable to take it with me on trips unless I bring a backpack. Doesn't fit well in my waist bag.
I have purchased a few genuine Nikon front lens caps as they do wear with being taken on and off after a while. Have even sourced some "copies " of the lens cap on eBay and they work OK. Nice thing, is that they are 50% of the Nikon price.+1If you want to try a UWA lens that doesn't break the bank, consider Rokinon/Samyang 14/2.8 prime. It is manual focus, but how much you really need AF for a UWA is questionable. The lens gets absolutely stellar reviews for sharpness. It does have a complicated distortion pattern but for landscape/nature it is probably not that big of a deal if any. Apparently fairly flare-resistant as well, which is a big deal for lenses with huge bulbous front elements, and I've heard that 14-24 doesn't fare exceptionally well in this department. The best thing, it costs a very small fraction of what you'll pay for 14-24, and it will give an idea of how much you really need UWA. I'm considering this lens myself because knowing how little use I'll probably get out of a UWA the expense seems commensurate.
Mine is very sharp. Color and contrast just like a Nikkor. It won't take a lens filter but does have a hard plastic front cover that snaps on. The 14-24 I rented came with a foam sock that you needed to slip over the front of the lens. Trying to do that in the field is a good way to drop something.
here are some samples;I have never been more pleased and amazed by some of the images have taken with this lens in my 40 years of picture taking. Not that it is always right for any situation, rather in those times that those images just jump at me there is no comparison. I have only owned this lens for less than a year and I do not foresee ever getting rid of it. You have to give it a chance to grow on you and it will reward you with images you will enjoy forever. Best lens ever.
I couldn't agree more. I recently purchased the 14-24 after a long debate between it, and the Zeiss 21mm. I was really torn but eventually decided I wanted both, but would buy them separately over a period of time. I got the Zeiss first, but received a bad copy (discussed in another thread), and I immediately exchanged it for the 14-24.The reason has been answered by a few posters here but to sum it up the 14-24 is a very specialized lens especially at the wide end and takes skill to use it. The majority that buy it are not skilled but collectors of trophy lenses and soon after buying realize they have no idea how to use it. All the catch phrases like "Holy Trinity" have been coined too often by amateurs as they worship their gear rather that using it. The good news for many is that these lenses are sold at a great discount second hand. The weight thing is a silly notion as how can one not understand the specs along with the filter issue. Does one fork out $2000.00 for a lens , then say" Oh s_ _ _t, this thing is heavy and darn it cannot take filters". That logic is juvenile but so often stated. The pixel peeping crtics are as usual, immersed in single minded useless specs as this lens is the benchmark lens of it's kind and you do not buy this lens for "perfect corners" however there are none better. It's the very common practice of amateurs buying gear they haven't a clue how to use so there should be no mystery at all.I have been considering buying a Nikon 14-24mm f2.8 for landscape photography. Here in Canada we have a popular free version of eBay called Kijiji.com There are always a number of these lenses for sale on this online market where the owner says they used it only once or a few times.
Why do you think that is? Is this lens too difficult to use? Is there too much flare? Are people that put off by no use of filters?
This is such an expensive lens I would assume that people would be slow to buy it new or used and would have done a lot of research before jumping in. Yet, so many buy it and then turn around and sell it without hardly ever using it. Just wondering.....
Rudy
it is hard to use because it is too wide, heavy and can't use filter. most people like 20mm better. Landscape doesn't need f2.8.
i have 14 24 and hardly use it however other people may use it more. all depend i guess. not everyone is the same
Obviously you didn't try enoughNow that I have owned and sold the 14-24, I think I'm now qualified to answer.
Let me preface that I had the 16-35VR for 3 years and loved it. Sold it for 18-35G because I wanted a lighter lens, and then sold it for the 14-24 because I wanted the best, or so I thought.
A big mistake. A confounding epic fail, if you will.
For the 14-24's first test, I took it to Yosemite. Within seconds of taking the first shots, I was greeted by flares...there were flares everywhere! And not just a simple flare, but the kind of flare that destroys the entire image. It didn't matter where the sun was - in front of me, above me, behind me, it would just flare. That was my biggest issue with it.
Then I started walking around the Merced River, where the great Ansel Adams have captured so many iconic landmarks in his time. I sat down and set up my tripod. Feeling inspired about the great framing and light that is about to shimmer on the unfolding scene, where El Capitan, Bridalveil Falls, and Merced River come into one. I reached for the LEE filter pocket and realized... "oh crap, this lens doesn't take filters!"
There I stood, bewildered.
I took a shot anyway, and the ever present flare manifested itself yet again.
"Ok, fine.", I said. So I took my rig and hiked the Four Mile Trail. There, I started to realize how heavy the 14-24 is, and how I constantly had to zoom in to 24mm to retract the bulbous element and protect it from Yosemite's wilderness.
Slowly, it dawned on me that the lens is actually a liability to my style of shooting - a detriment even. It's an event lens that is capable of shooting landscapes, but not the other way around.
On the way home, I looked at the 14-24. It was staring back at me, with its bulbous element exuding that arrogance as if saying "I am the best wide angle there is on the planet and you will never get rid of me". But I didn't care. Oh no I did not. In my mind, you are overhyped. An overhyped lens that is a product of the internet, where gear heads lurk who want nothing but the best, yet disregarding actual shooting conditions.
I arrived home and humbly packed the arrogant lens, off to its next owner.
I then acquired another 16-35 and I instantly felt like I was reunited with a long lost friend. Welcome back, 16-35VR, I will therefore wrap my arms around you tightly and never let go again. Good riddance, 14-24. At least I have lived with both and I can honestly say that it is the 16-35VR that I'm in love with. Oh the horror on the perfectionists faces.
A parting shot with the 14-24 and D800E. Yosemite Valley, September 2014.
