I'm not a professional, so keep your responses in layman's terms if possible. Which camera would you purchase and take with you - and why - to best capture the experience of a trip to Hawaii? I'm ultimately looking for which camera is going to produce the best quality pictures regardless of lighting, close-ups and landscapes, stills and action shots. This destination should challenge the camera as much as any, so versatility is key.
I don't mind the extra bulk of the a6000 and might like the option of using multiple lenses, but am probably more likely to use a more compact RX100 III in the long run - so long as there aren't any major concessions being made in quality. I've been going back and forth between the RX100 II and the Alpha a6000, but have dumped the II for the III in that equation and am now quite torn between the RX100 III and the Alpha a6000.
All the jargon and technical specifications are a bit mind-blowing at this stage, and I'm really searching for something that will tip the scale as to which of these identically priced options will best suit my needs while traveling, as well as at home. Thanks so much for any straightforward information or suggestions you can provide!
