I cann't agree with you. I have already a lens adapter - it does
blocks a viewfinder 50%, but who uses it anyway. It blocks
partially an AF assist but its functionality doesn't decrese, I
tested it in all light conditions - if the camera couldn't focus
with an adapter it also couldn't focus without it. So lens adapter
is not a problem. 420EX flash? You kidding me right? It works great
with G3, no problems at all.
So question still remains: do we need a UV/Haze filter as an all
time protection for the lens? Or it should be clear filter?
If you have any experience please share.
if everyone agrees, there'd be no forums, not much of one anyways. : )
i have both, the 52/58mm adapters on my g2/g2 black, and the 58 on
the g3.
i agree, the viewfinder is not in use most of the time, except when
the lcd's off when i'm trying to get high speed continous shots. my
problem's with the wide angle lens. the dia's too big and it blocks
it out, so, if i require a fill in, i wouldn't be able to use the
on board flash, thus, requiring the the 420/550. so now, i've got
added bulk/weight.
the automatic zoom on these flashes covers a range of '24-105mm'.
it follows the zoom on the camera if it's not bounced. when i'm
using a x0.4/x0.6 wide, the outer edges on the left and right will
not be in the flash zone. try it.
And when you add on the x1.4, the guide nos will not be 'as is' for
a coupla considerations, the camera will not know that the zoom
length has increased, esp when it's limited to 105mm on board. the
f-stop is also increased. ttl is not all it's hacked out to be.
whatever the case may be, i am a canon fan. almost all my digital
cameras are canon, with the exception of someother gimmicky ones. i
feel that being able to recognise the short comings helps you to
overcome them.
and this, is just my personal opinion. : )
http://www.the-inncrowd.com
