so, the new GH4 offers 4K video at 100mbps, and offers 1080p at 100mbps. I think that means that the 4k footage is being way more compressed than the 1080 footage - is that correct?
also, if the footage is being recorded at 100mbps, the file sizes for both 4k and 1080 would be the same - is that correct?
and lastly, if the file sizes are the same, why does it require such a much more powerful computer to render the 4k footage than the 1080 footage?
thanks.
jnorman
sunridge studios
salem, oregon
Panasonic GH4, Vario 7-14mm f/4
Cambo 45NX, nikkor SW 90/8, 135/5.6, 210/5.6
Graflex Crown Graphic 4x5 (1948 model)
My question to you is what is the encoder (codec) being used for 4k and 2k ?
If 4k is being compressed via the H.265 (new) encoder, while the 2k is being encoding using older H.264 encoder, then the resulting compression comparison may be more complicated that just numbers.
The H.265 is MUCH more efficient to encode, takes more h/w to encode & playback, much like mp2 vs mp4 playback. If decoding is done in h/w not CPU, a lesser issue.
4k is being encoded with 10bits, 422 subsampling, H.264 is 8bit, 420 subsampling, so which is the larger file - I would think 4k, 20% larger or more.
Playback of 4k is purely dependent on your graphics card, unless quite new, will NOT be used for 4k H.265 decoding, thus CPU usage will be large !! The CPU will be using software decoder I assume or graphics card might help in the decoding - not likely I think.
Generally, the higher the bit rate for Capture is desirable, then you decrease that after editing and for final product.
PS: ALL compression via any codec is NOT the same, some implimentations of codecs are better than others, sometimes hugely !! Just like JPEG renderings from raw.
Enjoy that GH4!
