... shows how to use exposure compensation and p41 shows filter compensation in 1/10 of an f/stop increments. This is not the 'tenths' place in a decimal number like f/5.6, but tenths of a full f-stop. This number is used when applying compensation to a reading, and should be zero when using the meter in simple aperture mode.I have bought a Sekonic L-758D, when setting the aperture in aperture priority and taking a reading, a number appears after the aperture selected, what does this number represent. Could anybody help, thanks
The small number to he right is the fractional part of an f stop. For example a large 16 followed by a small 7 is simply f16.7.I have bought a Sekonic L-758D, when setting the aperture in aperture priority and taking a reading, a number appears after the aperture selected, what does this number represent. Could anybody help, thanks
I may not understand the nature of your confusion, but let me try again. Shutter speed can be changed to cut the amount of light hitting the sensor just like aperture can. If you have the camera set to f/2.8 and 1/100 sec shutter speed, you can stop down a full stop by setting the aperture to f/4 or by setting the shutter speed to 1/200 (or some combination of those settings.) Of course, you could also slow the ISO by half if you so desired. All of these changes are equivalent in terms of the amount of light the sensor will record. So, if the light meter says you need to set the aperture to f/2.8.6, you could leave the f-stop right where it is and adjust the shutter speed to 1/160 sec (do two clicks faster on the shutter speed instead of two clicks smaller on the aperture -- they have the same effect on exposure. So there is no need to report the fine increment in more than one place -- there is a simple equivalence between these settings. HTHI understand the F stop settings re the lens on the camera and the increments in between the F stops, what I don't understand about the sekonic L-758 light meter is that when set to aperture priority and I have set the aperture to the desired F stop setting to suite the depth of field I require, why is the meter giving me an adjustment of the aperture at all, why is not just giving me the correct shutter speed,
ChrisThanks for your reply John, I'm beginning to understand that the numeral to the right of the selected aperture is a percentage of an F stop, displayed in one tenths. it just seems strange to me that when metering in aperture priority it then gives me an adjustment to make to the aperture of the lens rather than an adjustment of a partial stop with the shutter speed, especially as the L-758D instruction manual calls the numeral 1/10th shutter speed when in aperture priority mode. Thanks for every body's replies. Chris.
