Can get no better than large, Fine and 14-bit RAW, lossless.In my settings of my D7000, what file size creates the best enlargements?
So when is it better to shoot "medium" and "normal" (JPEG) when you think you might want the best quality enlargement?Not exactly.
Services that can make enlargements for you expect JPEG files. The reason to shoot in raw is that you can then take your time behind the computer adjusting settings for the conversion to JPEG rather than trust the camera to do this.
If you know you're not going to tinker with the image after the fact except maybe for some cropping then it's easier to shoot in JPEG. You then have a bunch of settings. Large = 4928x3264 fine and optimum quality give you the best quality files which are also, unsurprisingly, the largest.
Have a look at this blog post I did to see what happens if you go down in resolution or up in compression:
Nikon D7100 file sizes vs image quality
Remember that your camera shoots in a 3:2 aspect ratio, while enlargements often have different aspect rations (like 50 by 40 cm = 5:4 here in Europe) so your image may come out slightly cropped, so it's always a good idea not to frame too tightly. They also sometimes change the whitebalance, so you may want to try small prints first to see what you can expect and/or ask about this or read the service FAQ.
No, if you plan to print directly from the JPEG, you should set D7000 to save files not with "priority to size" but with "priority to quality" (check your manual, it's deep in the menus), then you choose "large" size and "fine" quality.So when is it better to shoot "medium" and "normal" (JPEG) when you think you might want the best quality enlargement?Not exactly.
If you know you're going to shoot something you're going to enlarge, shoot in large/fine.So when is it better to shoot "medium" and "normal" (JPEG) when you think you might want the best quality enlargement?
Your 100% right. Good tips. ...with enlargement in mind....large and fine, and as you point out, don't forget "optimal"...and 14-bit lossless when RAWNo, if you plan to print directly from the JPEG, you should set D7000 to save files not with "priority to size" but with "priority to quality" (check your manual, it's deep in the menus), then you choose "large" size and "fine" quality.So when is it better to shoot "medium" and "normal" (JPEG) when you think you might want the best quality enlargement?Not exactly.
AgreedThey will be in practice very close to the best you can achieve.
He asked what was the best and 14 is better than 12 but I agree with your point. I only shoot 14bit when Highlight detail is critical and extensive PP is anticipated.If you plan to do postprocessing, in 99% of the cases RAW 12 bit lossy is your choice.
I don't suggest 14 bit lossless because it is required in such extreme cases that if you were one of those, you would have the skills to choose by yourself without asking here (no offense intended).
